Truck wont start code p068A - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 4 Old 03-15-2012, 10:47 AM Thread Starter
Txsuperduty's Avatar
went to start truck just clicked sounds like starter. any ideas
2012 F250 6.7 4x4 CC Lariat
H&S MINI MAXX, DPF DELETE, 4" MBRP EXHAUST
Txsuperduty is offline
post #2 of 4 Old 03-15-2012, 06:47 PM
Ecm/pcm power relay disconnect.....................Something get left on? Check your batterys?
1998 Dodge 3500 Cab&Chassis, 12 valve, NV4500, 14' Flatbed
2011 Ford F-350 Lariat Crewcab, 6.7, automatic, 4x4 Traded in FERD on a Dodge!!! Back in the land of reliable diesels!
olypopper is offline
post #3 of 4 Old 03-16-2012, 03:07 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 4 Old 03-16-2012, 07:35 PM
Well? Any word on your truck? Did you get it started yet?
