Right rear brake lights quit - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 14 Old 10-25-2011, 04:41 PM Thread Starter
My right rear brake light quit working..
Everything else is working fine, even my right front
Blinkers...
I've traced the wires back to the firewll..
All fuses and relays are good..
I don't know where to go from here..
Please help!
2011 f-350 4x4 crew cab dually
2.5 inch lift on the front
Air bags on the back
200 hp
War hammer spartan and the dpf/cat delete
150 db - 150 psi train horn
Weather tech floor liners
Brand new flat bed
Mattress Guy is offline
post #2 of 14 Old 11-01-2011, 09:37 AM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Did you change the bulb?
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #3 of 14 Old 11-04-2011, 06:50 PM Thread Starter
I took the daily bed off and put on a flat bed...so it has fo ur brake lites..
But i did check the bulbs
200 hp
Brand new flat bed
post #4 of 14 Old 12-09-2011, 11:48 PM Thread Starter
Well now i dont have any brake lites on the back of my truck
And I never could find any one that could fix the rite rear brake lites...
All my front blinkers work but nuthin on the back..
All bulbs , fuses, and relays are good..
I really feel like there has to be something that splits the front
From the back, and that is prolly the problem
200 hp
Brand new flat bed
post #5 of 14 Old 12-11-2011, 10:23 AM
Quoted: 2 Post(s)
Have you checked the housing for shorts with a test light or connected it to a different power source?
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #6 of 14 Old 12-25-2011, 10:36 AM
fdny136's Avatar
Quoted: 6 Post(s)
i saw a tech bulletin online for body installers re: 2011 and it was special instructions for rear lights on truck
2017 f250 superduty 2.5 carli leveling
fdny136 is offline
post #7 of 14 Old 12-25-2011, 10:38 AM
fdny136's Avatar
Quoted: 6 Post(s)
this may help?https://www.fleet.ford.com/truckbbas.../Q-190R3v2.pdf
fdny136 is offline
post #8 of 14 Old 01-23-2012, 08:53 AM
Castaway's Avatar
I have the same problem with mine. Began with no Right Stop/Turn, then both sides on rear quit. park lights still work, My turn signals still work on front and mirrors. and 3rd brake light still works. I have checked fuses and relays but no luck so far. Going to study Service Bulletin and see if it gives any help. Will let you know if I have any luck.
Castaway is offline
post #9 of 14 Old 01-23-2012, 03:50 PM
Castaway's Avatar
After we spoke this morning my left side started working again, I disconnected all three lights on Right side of body then checked with meter and still no power. I talked to Ford Corp. and now it is in the hands of my local dealer. Hopefully I will have a solution to pass on to you soon.
2011 F450 6.7 Lariat Pro Hauler
Castaway is offline
post #10 of 14 Old 01-26-2012, 09:48 PM
Castaway's Avatar
I got my Truck back after they replaced the BCM and everything worked for about an hour before problem resurfaced. Mine has four bottom lights and two in Head Rack. I changed all bulbs to LED and then took a 6 hour ride with no more problems. I think problem is solved and Pray I am correct.
Castaway is offline
