2011 F 250 Powerstroke rear window leak - Ford Powerstroke Diesel Forum
6.7 Problems Forum (2011-2016) 6.7 Problems Forum
post #1 of 10 Old 08-08-2011, 03:45 PM Thread Starter
Hello,
Back in November 2010 i purchased a brand new 2011 Ford F 250 Powerstroke. About 6 months after I had it I noticed that my rear automatic sliding window was leaking,leaving water on the inside of my back window and some of my seat. Now it doesn't leak when it rains, just when i run it through an auto wash or when i hand wash with a regular garden hose. When i took it to the dealership for this problem they stated that they weren't sure how to fix the problem and they would have to contact the Ford tech-line for further instructions.Keep in mind the sticker price on this truck was(are you sitting down) $60,155. So the tech line then contacted my dealership a few weeks later and stated that they didn't have a fix for the problem at this time. So my service manager stated that i should contact the Ford customer relations department and tell them the problem and that they would handle it from here. Kind of weird that i would have to call,but i did and stated my problem with the Ford CRD. He told me the same thing that there wasn't a fix at this time and that he would have to turn my problem over to the customer care team.He said that CCT would investigate my problem and that somebody from the team would contact me in two business days. It was more like six. He went over my problem with me and basically told me that the window was "DESIGNED TO LEAK" and it was a characteristic of my vehicle. This is the most ridiculous thing i've ever heard. He stated that since its a characteristic of my vehicle that their is nothing they can do to fix it. He stated that my truck has a trough under the slider that catches the water that leaks in and drains through hoses that run outside the vehicle. I have torn apart that back seat(short of taking out the seats)looking for this trough and hoses. Im not seeing a thing other than the housing for the cable and the rear window motor.I was just curious if anybody else has had this problem or something like it. Or any advice on what you think my next steps should be. I have already filed a complaint with the BBB and waiting to hear back from them. If I would have known about this so called "characteristic" I would not have bought the truck. Im a blue collar working man that has a very expensive truck. I sure as hell don't want it to leak.
Thanks For Listening
Matt Demmin
MDemmin is offline
post #2 of 10 Old 08-08-2011, 04:01 PM
There's no way the characteristics of the truck is to leak water in the cab. And there is no reason for you having to look for the problem, the sliding rear window has been around for years and many don't leak including mine. Maybe you could try a different dealer.
2011 F250 6.7 Lariat Ultimate FX4 CC Tuxedo Black Tan Bottom
stroke11 is offline
post #3 of 10 Old 08-08-2011, 05:12 PM Thread Starter
Thanks stroke11,
I think I will give another dealer a try just to see what they say.
MDemmin is offline
post #4 of 10 Old 08-08-2011, 08:03 PM
mor4wd's Avatar
+1 on trying a different dealer. Mine doesn't leak and there would be a real problem if it did.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #5 of 10 Old 08-08-2011, 08:10 PM
tjbrowder's Avatar
Agree with the others....that response would be a "no go" in my book.
Take it to another dealership. Make sure you get everything documented from all involved in case you have to escalate things further up the ladder.
2011 F450 CC/LB 4X4
2010 F250 CC/SB FX4 *SOLD*
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website (Powerstroke.org or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
tjbrowder is offline
post #6 of 10 Old 10-06-2011, 10:37 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Any Updates?
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #7 of 10 Old 10-06-2011, 12:08 PM Thread Starter
Yeah.... Sorry about not posting the update. I ended up taking my truck to different dealer. It turns out that 3 out of 4 seals were bad and they replaced all of the seals.
So far i have had no leaks and I had no problems at all with the other dealer and everything was covered under warranty. Thanks for all of the advice...
MDemmin is offline
post #8 of 10 Old 10-06-2011, 12:16 PM
Quoted: 4 Post(s)
Good job Man! Thanks for the update. Glad to hear it worked out for ya.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
post #9 of 10 Old 07-18-2012, 11:15 AM
I have the same problem. Thanks for the update. I'll go to the dealer prepared
2011 F250 XLT 6.7 PSD 4X4 Crew 3.31 rear-end in Sterling Grey
1tough_crew is offline
post #10 of 10 Old 07-31-2012, 06:22 PM
The dealer said that it's the seal around the extra brake light that is allowing all the water in. He is ordering the part and I will let you know if it works
