adding cab lights? - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion 6.7 Powerstroke Interior Discussion
User Tag List
 3Likes
post #1 of 28 Old 05-06-2013, 03:36 PM Thread Starter
adding cab lights?
so i am looking to buy a new truck and if i do purchase it i would want to install cab lights because it does not have any. do you guys recommend it because i was thinking do i really want to drill into my head board and have the chances of leaks and what not? i need some input!
larswadensten is offline
post #2 of 28 Old 05-07-2013, 04:36 AM
jaysshortbus's Avatar
I have always wanted to put some on my Excursion but affraid of drilling my roof !!
Jay
jaysshortbus is offline
post #3 of 28 Old 05-07-2013, 06:07 AM
dodge_dbag's Avatar
http://www.ebay.com/itm/FORD-F250-F3...0dfb65&vxp=mtr
I have been thinking of buying this one.
08 f450 xlt fx4
11 f350 king ranch fx4
12 f250 lariat fx4
dodge_dbag is offline
post #4 of 28 Old 05-07-2013, 06:18 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
It's not as hard as you think...
All you have to do is measure...Measure...MEASURE!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
LED Light Upgrades from Retro-Solutions 08-10 Side Mirrors from 1A Auto
dfuzz78 is offline
post #5 of 28 Old 05-07-2013, 07:19 AM
Chapter Director
Rammstein1224's Avatar
Feedback Score: 5 reviews
Its not really that hard like he said i did it to both my trucks, just make sure to mock them up when you get it all measured to make sure it looks good to you before you drill. and make a template of the base of the lights it makes it way easier to mark holes
but as for where to get them just go to the junkyard, i got all 5 lights and harness for like 30 bucks because they are scrap pricing it so they have no idea how much they are worth
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 28 Old 05-07-2013, 07:21 AM
I'm taking mine in to let the pros handle this one... Don't have the Ba**s to drill the holes. I have a reputable Truck Accessory shop who's charging $350 for OEM installed. But, to make sure they do it correctly, I found this picture online and created a diagram. PLus I'll be there to look at the planned placement before they drill
2012 F-250 Lariat FX4 Ultimate/Chrome Package, CC SB 3.55 ELD, Clearance Lights, Rapid Heat, Upfitters, HD Alternator, Snow Plow Prep, PTO, Husky Liners, Arma Spray-in Bed Liner, Bakflip F1 Tonneau, BFGoodrich All-Terrain T/A 325/65/R18 on Stock 18's
AK250 is offline
post #7 of 28 Old 05-08-2013, 10:06 AM
LOL Its not that hard at all. Did mine in about an hour. Just make sure you spend 90% of that time on Prep. I taped off the top of the truck in the area to put the lights and then placed the lights in my measured spots and visually make sure they looked right. Then measured over and over again. Once I had that all done I drilled LOL.
dfuzz78 likes this.
FastCarsSpeed is offline
The Following User Says Thank You to FastCarsSpeed For This Useful Post:
dfuzz78 (01-10-2015)
post #8 of 28 Old 01-10-2015, 02:39 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 214 Post(s)
do they all face perfectly forward or do the outside ones angle out a little?
Keith
2014 F250 Platinum FX4
AFE Intake
Sct x4
4" Dual Exhaust no muffler with 5" MBRP tips
4" BDS with Fox shocks
20x9 Gear Alloy Big blocks 0 offset
35" Toyo AT2's
Procomp Pro runner dual stabilizers
strokinpower is offline
post #9 of 28 Old 01-10-2015, 03:10 PM
dfuzz78's Avatar
They are all straight forward.
The curvature of the roof makes it look like they are a tad askew.
Denis "Lt. Sled"
dfuzz78 is offline
post #10 of 28 Old 01-10-2015, 05:08 PM
Kustom4x4's Avatar
I wish my truck wouldn't of had them on there....but since they do I'm thinking about getting the dodge ones as they look better, and seem to stay in place better than the ford ones, they are a little sleeker looking
01 Platinum
8inch lift
22x11 KMC Diesels/37x13.50 Kumho MT's
2015 Platinum Bronze fire
Soon to come
4" BDS lift
22x12 American force wheels and 35's
Kustom4x4 is offline
