| 6.7 Powerstroke Interior Discussion 6.7 Powerstroke Interior Discussion |
weird noise drivers
I have a noise coming from like the seatbelt adjustment area on the drivers side. Its almost like the trim in the outside is flapping in the wind at high speeds, but its not ofcourse. Anyone experience this? 2011 lariat thanks in advance
Me 2 i checked th window and its loose. Put window down about 3-5 inch the push from inside it may be loose. I checked the rest of windows and no play.
same here, mine seems to be the head liner next time you here the noise try pushing on the drivers side head liner right where the airbag emblem is.
I have the same **** and I would love to hear from someone that fixed it. It isn't on the passenger side only as the OP described it on the drivers side. I just ordered some latex tubing for the door seals and hope it helps but don't think it will much. If you look at the door area with the drivers door open there is a little rubber ****er that just looks like it resonates at the exact ****ing frequency this noise I'm hearing is.
Its driving me crazy... Im bringing this up when I take it to get serviced
They what ever they did the humming stopped coming from the instrument cluster. But, that dam drivers door drove me plum crazy. I need to get this fixed.
