Ok so if anyone has seen the Need for Speed movie with "the Beast" there is a scene in which you can see an on top of the dash CB mount that looks pretty good. I have a 2013 F250 with the Navigation screen so wondering if anyone out there has seen this mount, or something that could be used similar...please help.
I found a VERY short glimpse of what you reference. I'm sure it's either custom or you will have to scour the internet. It would be nice to have so I can get mine out the center console.
here are a few pics of what i'm looking for or similar...It's got to be custom since i cannot find anything on internet like it...anyone have thoughts?
No pics showed up. I used to mount mine to the headliner so the mic cord hung down like a big rig.... I don't have one anymore but if we get a toy hauler like we plan then I'll need some ideas.
Sorry here are the pics...No I wont bolt to dash, this would sit on top...trick back is since my truck does not have the flat dash, and has the 2013 version with myford touch screen the bottom of dash would be tricky, but this looks pretty sweet.
This would be perfect for running two radios. I have a CB and would like to install a VHF 2 meter as well. Only problem is the CB is taking up the only good spot. On the side of the center console. I don't like the idea of pulling the cupholders because I always have stuff setting there.
That setup drops into the open pocket model trucks. With the MFT screen you have a lid that covers the other media/USB connections. You could make something out of kydex as a start for the bottom. Just build off of that and you can do it.
This is how I mounted the remote head of my Kenwood dual bander. Just took out one of the sunglass holders from the overhead console. The console is just held in with clips so easy to pull down. The main body is mounted to the firewall behind the emergency brake (actually lots of room)
I also installed a Cobra 75 where almost everything is in the mic. I installed the junction box under the console, but am thinking about relocating it so I can get to the antenna connection easier, having trouble getting it tuned.
I had originally thought about setting it up that way but didn't want to hack up the tray to make it fit. It's just a little awkward with the control cable connection on the side.
I hear you on the bi-focals, I haven't quite graduated there yet, but probably should.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
