Anyone replaced factory sub with upgrade using factory sub box? - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 8 Old 10-12-2013, 05:07 PM Thread Starter
I have 2013 fx4 crew with sony system. I am interested in staying stock look but upgrading sub and possibly amp. Has anyone replaced the the stock sub with upgrade sub and amp but kept stock box? If so, what did u get and how do u like the sound?
sack004 is offline
post #2 of 8 Old 10-22-2013, 06:53 PM
Also curious
2012 6.7L King Ranch Bronze Metallic
Traded up from 2003 Avalanche 5.3L
CW2 US Army
Currently: Watercraft Engineer
Previously: Prime Power, Recruiter, Infantry
Prime Power is offline
post #3 of 8 Old 10-25-2013, 05:54 PM
Its probably terrible from limited air space
nateneill is offline
post #4 of 8 Old 10-26-2013, 09:57 AM
Traveling Man's Avatar
I installed a Helix 8" shallow mount and a R. Fosgate 2-channel in the existing enclosure. Better than the stock set-up but not worth the money I spent. One day I will get a custom box and install a single 10" and use the same amp.
Traveling Man is offline
post #5 of 8 Old 10-26-2013, 05:35 PM
Quoted: 10 Post(s)
The factory sub and enclosure is crap. I bought the SPL2K box and the 13TW5 powered by the XD600/1. You can pull the high level signals off the OEM sub output. The MFT Sony system has the 10 channel amp for the whole system behind the OEM sub enclosure. It's not a separate sub amp like the 12s and earlier trucks.
2013
F350 Lariat Ultimate FX4 CC LB SRW
jetskier is offline
post #6 of 8 Old 10-26-2013, 06:26 PM
Quoted: 2 Post(s)
Can anyone post pics of their setup?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #7 of 8 Old 10-27-2013, 04:26 PM
Quoted: 10 Post(s)
http://www.powerstroke.org/forum/6-7...ml#post6927257
2013
jetskier is offline
post #8 of 8 Old 10-31-2013, 08:24 PM
Not to mention that each sub requires a specific amount of air space for optimal acoustics. Your best bet if you want to reuse the enclosure is to measure the air space in the factory box and fine a woofer that would perform well in it. Of course you would then have to power the sub accordingly. Not sure if it's worth the hassle.....
blacknight is offline
