How to remove door panels - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 15 Old 08-24-2013, 01:40 PM Thread Starter
Quoted: 2 Post(s)
Does anyone have any tips of a write up on how to change the door panels to get to the speakers?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 15 Old 08-26-2013, 09:03 PM
brandonlee0034's Avatar
It's easy there are 4 bolts total, 2 on the bottom 2 in the pocket on the side of the door behind a plastic insert piece that pops out. Pull the tweeter off by the a-pillar and unplug it, then pop off the plastic piece with the window switches and unplug that. Then just lift up and pull out.
2011 F250 6.7
Stock...?
brandonlee0034 is offline
post #3 of 15 Old 08-27-2013, 02:14 PM Thread Starter
Quoted: 2 Post(s)
Thank you for the good info.
wreedPS is offline
post #4 of 15 Old 08-30-2013, 04:28 PM Thread Starter
Quoted: 2 Post(s)
How about the rear doors, any tips of tricks there?
wreedPS is offline
post #5 of 15 Old 08-30-2013, 05:44 PM Thread Starter
Quoted: 2 Post(s)
Got the 2 new front speakers installed in less than 1 hour. Thanks man!
I went with Alpine Type - S
I will do the rears next.
This gave me a good chance to clean everything too.
wreedPS is offline
post #6 of 15 Old 08-31-2013, 11:34 AM
The rear speakers aren't behind the door panels like in the front, so I'm not sure what you're trying to remove them for. Pretty much the same removal steps though unbolt it take out the window switch and unplug it then pull the panel off a little then disconnect tweeter.
2011 F250 6.7
Stock...?
post #7 of 15 Old 08-31-2013, 11:35 AM Thread Starter
Quoted: 2 Post(s)
Ya I saw they were not in the doors after I posted that.
wreedPS is offline
post #8 of 15 Old 08-31-2013, 11:41 AM
You found them behind the plastic panels behind the seat I'm guessing?
2011 F250 6.7
Stock...?
post #9 of 15 Old 09-03-2013, 05:04 PM Thread Starter
Quoted: 2 Post(s)
What is the easiest way to access the rear speakers? How is plastic disassembled?
wreedPS is offline
post #10 of 15 Old 09-04-2013, 07:50 PM
I thought they were kind of a pain. Just flip the top half of the seat down and pull the grey plastic piece off that connects to the different trim going up the back corner wall. You'll see the speaker shape in the plastic once you flip down the back seat.
2011 F250 6.7
Stock...?
