08-10 center console installed in 2012 - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 11 Old 06-20-2013, 04:39 PM Thread Starter
installed a 2008 center console in my 2012 F-350 today, removed the jump seat. the jump seat comes out pretty easy two bolts in front and two in the back. the front bolts are under the bottom tray. the two rear bolts are easier to get if you remove the inside seat bolts (need to anyways). Unplug the harness and the seat comes out, easy.
now the 08' console. the rear bracket bolts right in no problems, just slides in under the rear seat legs. the front bracket dose not fit, I guess with the new transmission they changed the center hump. to get it to work you half to cut a 1"x5.5/6" section out of the front of the legs. its pretty easy to see what you need to cut off when you lay the bracket in there.
before you can bolt the console in you have to redo the wiring (the plug is different). on the console I unplugged the front power point, and cut the rear plug wires off the connector, you can then pull the harness out leaving the rear plug and wires in place. I got the harness off the jump seat which snaps in the console. the power point plug is the same so it plugs into the front, then I just spliced in the rear wires.
when I tried to put the console in the center hump again caused problems. the rear was fine bolts right down. the front had about a 5/8" gap that I had to fill between the bracket and the console, needed longer bolts to. the gap did not make sense but if I pushed the console down its was not level. the plastic an the driver side was to long, I had to cut a lot off up to the bottom snap where the cup holder plastic snaps on. the passenger side is fine no cutting needed. you also have to trim under the front pocket about a 1/4" for the length of the pocket.
after everything is snapped in and tight it looks pretty good. you do have two bolts in the rear that are unused where the jump seat bolted down, and a small 1.5"x1.5" square carpet missing around both bolts. I used black felt to fill the holes, slid it under the carpet and put caps over the threads.
lmc122 is offline
post #2 of 11 Old 06-20-2013, 04:46 PM
05_PSD_Erik's Avatar
I'd like to see the pics of how this turned out. Sounds like a cool idea for those with Jump seats..
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #3 of 11 Old 06-20-2013, 04:48 PM Thread Starter
here's some pictures after I installed it.
ID:	127898   Click image for larger version
ID:	127906   Click image for larger version
ID:	127914   Click image for larger version
ID:	127922   Click image for larger version
lmc122 is offline
post #4 of 11 Old 06-20-2013, 04:54 PM Thread Starter
some more pictures!
ID:	127938   Click image for larger version
ID:	127946   Click image for larger version
ID:	127954   Click image for larger version
ID:	127962   Click image for larger version
lmc122 is offline
post #5 of 11 Old 06-20-2013, 05:02 PM
ZMANN's Avatar
Quoted: 1775 Post(s)
looks like a good match
mine was too far forward for Me so I made billet blocks to move it back and up on my o6
We Miss you Ronnie
ZMANN is offline
post #6 of 11 Old 08-21-2013, 06:43 PM
1stnlast59's Avatar
That's awesome. I'm gonna find one for mine cause I've got the 4x4 shifter in the floor. This would b perfect
1stnlast59 is offline
post #7 of 11 Old 08-24-2013, 04:48 AM
1stnlast59's Avatar
If anyone knows where I can find one of these. Let me know. I've looked all over. The only ones I've found are like $600+ on ebay
post #8 of 11 Old 09-12-2013, 06:42 PM
1stnlast59's Avatar
So I bought one of these consoles. Actually I might as well have stole it. But it doesn't have the brackets. Anyone know where I can get the brackets. I found some on eBay but the brackets are $80 a piece.
post #9 of 11 Old 09-24-2015, 08:59 AM
CaseyJ's Avatar
Quoted: 5 Post(s)
Garage
The question I have is, Can you install an '11 and up console in a 08-10? If so, my google fu seems to be weak and can't locate the thread. Thanks in advance
2009 F-350 FX4 CCSB
ARP Head Studs
Mahle Pistons
XRT Pro single tune
Vermillion Red
2011 F-350 King Ranch CCSB FX4 SOLD
Royal Red Metallic
2008 F-250 Lariat 4x4 CCSB SOLD
Jan2007 "Job1"
2001 F-250 ECLB SOLD
AFE Stage II Intake
MBRP 4" Turbo Back Exhaust
CaseyJ is offline
post #10 of 11 Old 09-24-2015, 10:10 AM
Quoted: 48 Post(s)
yes, be sure to get the dash trim piece
drunk on diesel is offline
