trailer disconnect - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 13 Old 02-20-2013, 06:12 PM Thread Starter
trailer disconnect
for some reason my information screen continues to show trailer disconnect while my tralier is hooked up and driving and i know its not any help would greatly be appreciated brand new trailer
blackmouthd is offline
post #2 of 13 Old 02-20-2013, 06:58 PM
sombrero's Avatar
Check your trailer plug on the truck. We had to replace a plug on one of our f250's at the ranch. We experienced the same scenario, and determined the truck plug was the culprit.
2012 Ram 3500 Cummins-Work Truck
1997 F250 4X4 Crew Cab Short Box ZF-5 -Toy
sombrero is offline
post #3 of 13 Old 02-20-2013, 07:05 PM Thread Starter
how do u check it
post #4 of 13 Old 02-20-2013, 07:40 PM
sombrero's Avatar
A simple way to check would be to hook up another trailer and see if the message repeats itself. If it does take it to the dealer and have them test the trailer plug to determine where the fault is.
sombrero is offline
post #5 of 13 Old 02-20-2013, 07:59 PM
Hooked on the POWER...
allenhood71's Avatar
Feedback Score: 6 reviews
trailer disconnect
Also you could plug b, turn your lights on and make sure the trailer lights up.
Sent from AutoGuide.com App
allenhood71 is offline
post #6 of 13 Old 02-20-2013, 08:02 PM Thread Starter
everything works brakes included but as u ride down the road everyonce n a while it pops trailer disconnected
post #7 of 13 Old 02-20-2013, 08:04 PM
gene c's Avatar
plug..........................
gene c is offline
post #8 of 13 Old 02-20-2013, 10:16 PM
trailer disconnect
Sounds like a bad connection to me.
post #9 of 13 Old 02-21-2013, 11:21 AM
Take the plug apart (cover should have a lockscrew holding it in place) and look for corrosion on any of the terminals. Also make sure the wires are screwed down tightly, they can come loose. If there is corrosion, get a wire brush and clean the terminals. Then clip the wire(s) at the end, strip off more insulation, and start with fresh wire in the terminals. Put a coating of dielectric grease (clear stuff in a can) over everything to protect it, water can get in those plugs and cause all sorts of problems.
rforsythe is offline
post #10 of 13 Old 02-21-2013, 04:37 PM Thread Starter
thanks yall
