Where to mount Valentine 1? - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 5 Old 07-17-2012, 04:59 AM Thread Starter
Where would I mount my Valentine 1? In my GM vehicles, they have power mirrors and I just tap into that. Am I going to have to run power all the way around down to the fuse block to have the V1 up by the mirror?
5W0P3 is offline
The Following User Says Thank You to 5W0P3 For This Useful Post:
paranoid1123 (10-24-2016)
post #2 of 5 Old 07-17-2012, 08:11 PM
rexrus's Avatar
My KR has power at the mirror as well. I do not have a camera in the mirror, so it's not going to be a camera only optioned power source. I have a escort unit mounted under the mirror and used the Invisible wire to tap into the mirror harness. I used the same one that I pulled from my GMC when I traded it. I'll post a picture to give you the pinout. Mine is a 2011, so a multimeter may help make sure you get the right wires.
Sent from my Autoguide iPad app
rexrus is offline
post #3 of 5 Old 07-18-2012, 12:03 PM Thread Starter
Unfortunately, I have an XL so i'm going to have to run a wire up the A pillar and under the headliner over to the mirror I guess
5W0P3 is offline
post #4 of 5 Old 08-11-2012, 06:41 AM
ATCguy's Avatar
I've mounted mine right under the rear view mirror in my last 3 Ford trucks using this, and it works really well. Completely clean installation.
BlendMount Custom Radar Detector Mounts Escort Beltronics Valentine One
For power, I have the upfitter switches... and just used the 10amp #3 switch wire located under the steering wheel. Ran the wire behind the A-pillar, and under the front lip of the headliner.
ATCguy is offline
post #5 of 5 Old 08-13-2012, 07:05 PM
2006F350's Avatar
I too used the #3 outfitter switch and this mount. Valentine Radar Mounts
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
