SAT Radio Malfunction - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 5 Old 05-10-2012, 12:27 PM Thread Starter
E-Town Throwdown's Avatar
Anyone else run into any problems with their stock radio unit in their 2011 SD Lariat? My satellite radio is only receiving a handful of channels and SIRIUS has reset my account and said it must be a hardware issue as everything is good with my account on their end. I'm thinking the unit must have gone bad or is malfunctioning since I can get probably 15 channels but that's it. Just curious if this has been a recurring theme through the community or if my stuff is all jacked up....
-Zaffy
SEMPER FI!!!
E-Town Throwdown is offline
post #2 of 5 Old 05-10-2012, 01:04 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
One question are your presets still workin....
Mine did the same thing.. then all the sudden i realized that to turn channels you have to use the up or down arrows by the cd insert not the sedways arrows below it.... i know for a fact when i bought the truck i had to use the sideways arrows to turn channels... like magically one day they changed spots..... i was totally lost for a couple weeks before i figured it out...
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #3 of 5 Old 05-10-2012, 05:48 PM Thread Starter
My first preset works but when I go to switch to the others it says "Unsubscribed Channel Call SIRIUS to activate" which I have done and they continue to claim everything is good to go on their end....the only channel that does work is a premium channel and those that don't are part of their basic lineup...it's both frustrating and weird at the same time...
-Zaffy
SEMPER FI!!!
post #4 of 5 Old 05-11-2012, 04:15 AM
Smoke Eater
there is a way you can re sync your sat radio to update it... call them or its on the website some where... i have had to do that before... sounds like to me thats all you need mine did the same thing... its a process where you have to go out have your truck on channel 1 or 2 i believe and they will resend you the updates takes like 20 mins....they will walk you thru it on the phone
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
fdchief is offline
post #5 of 5 Old 05-11-2012, 08:53 PM
E-town, your problem sounds just like mine. We tried everything to re-register the unit and no luck. I ended up having the radio replaced at Ford and everything is working perfectly now. Something in the radio just apparently died with respect to satellite. I would run it in and have them check it out. Good luck
jriltex is offline
Tags
6.7 , lariat , radio , satellite radio , sync
