HELP!! Problems with Hot while crank wiring - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 5 Old 04-07-2012, 08:54 AM Thread Starter
ulev1st's Avatar
I am attemping to wire everything up so I can install my tuner next week.
The H&S book says that the capped off bundle of wire near the OBD port have a purple wire that will provide what I need..
I located said wire and tapped into but I have NOTHING..I tested a FEW more ..NOT ALL of those wires that are bundled and capped and got nothing on any of them..
Am I in the right spot?
Where is a good place to find a HOT WHILE CRANK wire for the Mini Maxx?
Not sure if I'm messed up or what..
ID:	36410   Click image for larger version
2012 F250 FX4 Lariet..CC Short box.
2012 Mustang BOSS 302 Laguna Seca
2003 Powerstroke Crew cab Short bed (The Tow Pig!)JLP CAI, MBRP 4 in exhaust.(Retired)
1993 Mustang LX Notch..The race car.Low 8's@170+ in the 1/4!(sold)
ulev1st is offline
post #2 of 5 Old 04-07-2012, 09:22 AM
I think those are the pass through wires. The other ends are not attached to anything and are in the engine compartment.
2011 F-350 CCSB
powerstroke43 is offline
post #3 of 5 Old 04-07-2012, 09:41 AM Thread Starter
ulev1st's Avatar
Ok.....Where is a good source to pick up 12 v switch HOT WHILE CRANKING wire?
ulev1st is offline
post #4 of 5 Old 04-07-2012, 01:09 PM
My mini came with a fuse tap. The fuse box is on the drivers side under the hood. I think it was fuse 53? H&s has the instructions. I just ran the wire through one of the firewall grommets. You have to cut the end off the grommet and pull out the little rubber plug.
2011 F-350 CCSB
post #5 of 5 Old 04-07-2012, 02:45 PM Thread Starter
ulev1st's Avatar
Cool...Thanks...got it wired!
ulev1st is offline
