Center Console Removal - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 7 Old 02-05-2012, 06:38 AM Thread Starter
I am currently researching getting a new F-350 . I would like to get the Larriat model but would like the center console removed. I guess I could get one of the less optioned packages if I have to. I am the chief of my local volunteer FD and need to install several radios, siren box and switch boxes. I cuurently have them installed on the floor hump in my current truck. With the factory console there is no place to install them. I have looked at radio consoles from several manufacturers such as Troy and Havis that would provide a neat installation. Has anyone done this to their truck? Or where have you installed your radios, switches, CB, etc. Is the dash and carpeting complete below the console? The console that I have looked at would extend from the back of the front seat up to almost the dash I would guess. I don't want to hack apart my brand new truck and want to plan ahead. All new trucks seem to have similar consoles.
STGFIREFIGHTER is offline
post #2 of 7 Old 02-07-2012, 03:41 PM Thread Starter
Bump
Since it doesn't seem like anyone has installed a radio console in their new truck, could anyone tell me if looks like it can be removed easily? My friend has an '02 PSD with leather that I installed a switch box in the center console. I was able to remove it with just four small bolts. Are the '12's similar. Thanks for the help.
post #3 of 7 Old 02-07-2012, 04:39 PM
camdenlake's Avatar
Quoted: 15 Post(s)
What about getting mounts made to stash them in the console? That think is freaking huge. Just a thought. Thanks for the great work as a fire fighter.
Josh
1999 F150 4x4 With the not so stock V10
2009 Shelby GT500 - Grabber Orange
2012 F350 6.7 CC SB FX4 - Sold
2015 Explorer Sport - Black on Black - Sold
camdenlake is offline
post #4 of 7 Old 02-07-2012, 05:05 PM Thread Starter
I actually saw a photo of a nice clean install like that on the web somewhere. The problem is my current truck has two switch boxes, siren control, CB radio, scanner, UHF two way radio and low band two way radio. That amounts to about 20 inches of length if they are installed tight together. I don't think the console has that much room.
post #5 of 7 Old 02-07-2012, 05:10 PM
camdenlake's Avatar
Quoted: 15 Post(s)
A good audio place should be able to. Will take some measurements in the am.
Josh
post #6 of 7 Old 02-07-2012, 05:41 PM
radios in the console
Howdy Chief. I fully understand your problem with installing radios in these trucks. I have a 2011 XLT premium with the console and so am not sure my console matches the Lariat. I can tell you that the console has a ton of room in it and could hold several control heads or smaller radios plus the cup holders, in front of the console, just pop out and the area underneath the cup holders can hold more radios and control heads. If you dont mind giving up the console storage and the cup holders, the console can hold a lot of radio equipment. FYI, once you discover the secrets of removing the overhead console and overhead lights, you will find mounting antennas fairly easy as well. Coax cables can be run above the headliner, down along the pillars under the pillar covers, along the bottom of the door frame then through a channel under the drivers seat up to the center console. There are lots of possibilities. Good luck.
hamradioactive is offline
post #7 of 7 Old 02-07-2012, 05:41 PM
You would better off in a truck with a jump seat and taking out the seat. If you remove the console you would have to buy the flip down cup holders and the bottom dash part.
2011 F-350 CCSB
powerstroke43 is offline
