2 Annoyances - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 12 Old 12-29-2011, 08:50 AM Thread Starter
2 Annoyances
#1 - Not enough head clearance. I'm only 6'2" and I have to NOT sit up straight or my head brushes the roof. At first I thought my seat was raised, but it's as far down as possible. I wish they would have made the seat with the ability to lower further. I do have a moon roof; is there more clearance without one?
#2 - The driver's floor mat latch/holder is in a position where I naturally want to set my left foot. Actually my heel is generally right on it or I have to move my foot around it. I haven't checked how it's connected, but if it's just a plastic notch I may dremel it off. It seems like this could have been placed on the right-rear side as this foot is generally on a pedal.
Does anyone else get annoyed by either issue?
FordOD is offline
post #2 of 12 Old 12-29-2011, 09:12 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Can you lower your seat? Fords boast the most head room out of the big 3
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 12 Old 12-29-2011, 09:31 AM
Yes, the Moon Roof takes up a Couple more inchs than the Non-Moon roofs Kinda Sux IMHO.....
I Think some of the Reason it's so thick/couple inchs lower ,is not only for the Glass to have a Place to go but also for crash protection....Air Bags,as i'm sure they prolly put some in that area...
Not sure about your Floor mat thingy But sounds like you already have the answer :~) If you can't change it around or remove it,Then Mod it with the Dremel.....If possible.
Lead Foot is offline
post #4 of 12 Old 01-01-2012, 07:20 PM
Problem is they changed to the F150 style seats without changing to the F150 bases in the floorboard...I too am 6"4" and have complained about the headroom cause it sucks. If you go look at a F150 the further back you move the seat the lower the seat goes...which makes sense. But in our F350's you move level as you move back. I am fearful if I actually hit a bump off road I may injure my neck. My MY2000 F350 allowed me to wear a cowboy hat...in this think I can barely wear a dew rag. Sad design.
jriltex is offline
post #5 of 12 Old 01-02-2012, 08:09 AM
2006PSDSD's Avatar
Quoted: 24 Post(s)
That sucks they did that! Dumb mistake, since PSD owners are not exactly, small
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #6 of 12 Old 01-02-2012, 08:36 AM Thread Starter
Thanks for the answer! I figured the moon roof played a part, but thought something else had to have changed. Seriously, if I was much taller, I would make sure I didn't have the moon roof, and then if it was still a problem it could be a deal breaker.
I took care of the carpet catch. It's just clipped on with the opening of the clip toward the front of the truck. Pried a flat head in there and got it off. I didn't realize there is a second one on the right, so it still holds in place.
FordOD is offline
post #7 of 12 Old 01-03-2012, 10:37 PM
2006F350's Avatar
I too hate the seat height, even makes it harder to get in and out and see some traffic lights. I have no moon roof.
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
post #8 of 12 Old 01-04-2012, 05:40 AM
2006PSDSD's Avatar
Quoted: 24 Post(s)
you guys should have drank more coffee in your teen years
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #9 of 12 Old 01-04-2012, 06:00 AM
majek5's Avatar
Being 6'4", this doesn't make me too happy either. Maybe in 5,6,8 years, they will have this fixed...when I will be ready for a new one. My 6.0 has tons of head room.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #10 of 12 Old 01-04-2012, 02:23 PM Thread Starter
Looking under the seat, it looks like they could just release a redesign on the corner brackets that the seat mounts to. I wouldn't mind having a set of low-profile brackets and changing them out myself. Could this be done after market? My only concern would be to maintain the safety of the overall design with how the seats attach to the floor. There is a good 3" that could be gained.
FordOD is offline
