cargo lamp - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 7 Old 11-21-2011, 05:38 PM Thread Starter
fdny136's Avatar
Quoted: 6 Post(s)
cargo lamp
dont know what happened changed the cargo lamp bulbs all was well.now suddenly nocargo lamp or dome lamp when i open my doors.I checked all the fuses and they are good.anybody have anything like this happen? what did you do ?
2017 f250 superduty 2.5 carli leveling
fdny136 is offline
post #2 of 7 Old 11-21-2011, 07:45 PM
mor4wd's Avatar
Can you get it to come on when you push the dimmer switch up for 1 second?
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 7 Old 11-22-2011, 06:14 AM Thread Starter
fdny136's Avatar
Quoted: 6 Post(s)
no does not come on with dimmer
fdny136 is offline
post #4 of 7 Old 11-22-2011, 06:36 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 7 Old 11-22-2011, 06:42 AM
mor4wd's Avatar
Are you sure you replaced the bulbs with the same exact style. All the lights turn on and off via the computer. Pushing the button or opening the door only tells the computer to turn it on. If it senses a different resistance in the bulb or if you put in an LED it probably won't work. However if you were real savvy with electronics you could probably figure out the correct resistance and wire up a resistor to simulate the right style. I'm only assuming you changed bulb styles because I can't possibly see any of these bulbs burning out so quickly. My apologies if I'm wrong.
mor4wd is offline
post #6 of 7 Old 11-22-2011, 09:16 AM Thread Starter
fdny136's Avatar
Quoted: 6 Post(s)
put leds in worked initially then a day later no light so I put the stock bulbs back in
fdny136 is offline
post #7 of 7 Old 12-01-2011, 06:18 PM
fdny136...& mor4wd..question & answer... how do u get the lense down on the front map lights. i've got the overhead with the moon roof and rear window slider switches. the rear seat dome and maps lense was hard to pull down... but she finally popped. i installed the 3 led's and still working. one thing i noticed... is that if i installed an led and it did not work, i'd flip it around and to my amazement it would lite. not sure why.... but the cargo,,hi-mount stop, rev, and lic. plate led's all had the same symptom..it was a 50/50 shot.. some worked--- some not---flipped it around and now they all work. i still have the fr & rear turns and the led hidden strobes to do.......please shed some kight on the front lense removal. thanks and think snow
dc.snowball is offline
