Easy-Access/Easy-Out Feature Questions? - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 11 Old 06-27-2011, 12:38 PM Thread Starter
gldubzakjr's Avatar
Send a message via Skype™ to gldubzakjr
I purchased a, what I believe is a Job 2 (Build date 10-22-2011, Kentucky Truck Plant) 2011 Ford F-350 Lariat Diesel, with just about every option installed; however, when following the manuals instructions to enable the "Easy-access/easy-out feature" for the drivers seat, the process never seems to work (Instructions below).
Easy-access/easy-out feature (if equipped)
The easy entry feature can be turned off or on through the vehicle
message center. Refer to Message center in the Instrument Cluster
chapter.
The easy entry feature automatically moves the driver’s seat 2 inches
(5 cm) forward when:
• the transmission is in P (Park)
• the key is inserted into the ignition cylinder
(If the seat is located less than 2 inches [5 cm] from the front of the seat
track, the seat will travel up to 1⁄4 inch (6 mm) to the front of the seat
track).
The easy out feature automatically moves the driver’s seat 2 inches
(5 cm) backward when:
• the key is removed from the ignition cylinder
(If the seat is located less than 2 inches (5 cm) from the rear of the seat
track, the seat will travel up to 1⁄4 inch (6 mm) to the rear of the seat
track).
If the memory setting is programmed through the remote transmitter,
upon unlocking the door via remote entry system, the seat position will
travel to the desired memory setting less 2 inches (5 cm). Once entering
the vehicle and inserting the key in the ignition while in P (Park), the
easy entry feature will move the seat an additional 2 inches (5 cm) to
the desired memory location. See Locks and Security for activating the
memory seat feature through the remote entry system.
I was at Pacifico Ford this morning for an oil change and to address this issue and the technicians basically told me that my vehicle may or may not be equipped for this feature and that they we're sure how to find out if it was.
Question# 1: Does anyone out here have this feature on their truck and if so, when was the vehicle made (Build date and factory)?
Question# 2: How do I find out if I, in-fact do have this feature?
Question# 3: How to I access it or advise my dealer accordingly?
Aside from this issue; I am also have issues getting my dealer (Pacifico Ford) to research firmware updates on my truck via OASIS. I have a rough shifting issue, which I know was covered under a previous TSB 10-23-9 and there have also been later releases as well.
Question# 4: Can anyone recommend a good DIESEL Ford Dealer in Southern NJ?
Thanks in advance...
Jerry
gldubzakjr is offline
post #2 of 11 Old 06-27-2011, 01:34 PM
My build date is 5/11 F350 Lariat CrewCab fully loaded and the easy-access and easy out feature does work. As soon as I put the key in the seat moves forward and when I remove the key the seat moves rearward.
No idea on how to check the computer to see if you have it or if it can be disabled or enabled.
you really shouldn't post your VIN# out in the public eye
jjmstang is offline
post #3 of 11 Old 06-27-2011, 01:59 PM Thread Starter
gldubzakjr's Avatar
Thanks for the tip on the VIN, I just removed it. I was aware how the feature worked as I have had this on numerous other Ford's I've owned and I do enjoy and find it VERY handy, especially running emergency scenes and needing to jump in and out of the truck quickly.
Hopefully someone else can shed some additional light on the topic.
Thanks for the comment...
Regards,
Jerry
post #4 of 11 Old 07-13-2011, 12:53 PM
psdcasper's Avatar
To enable it or disable it should be under the vehicle settings on the screen in the dash. I disabled mine because I run with my seat all the way back so it really does me no good. Hope this helps. Let me know if you can NOT find it and I will check on mine exactly what sceen it is on.
2015 F-350 CCLB Loaded, Lariat Ultimate, FX4 Off Road Pkg, Reese 5th/Goose Hitch, Fully Loaded.
2014 VW Passat TDI (DIRTY DIESEL
)42mpg on the highway
(Wife's Ride).
2011 F-350 CCSB 6.7L, Loaded, Lariat Ultimate, FX4 Off Road Pkg, Reese 5th/Goose Hitch, White on Black. (43K as of 4/14) H&S Mini Maxx, Flo Pro delete pipe, Magna Flow Muffler and Sinister EGR Delete . Sold 2/15
psdcasper is offline
post #5 of 11 Old 07-26-2011, 07:08 PM Thread Starter
gldubzakjr's Avatar
I finally heard back from Ford engineering today on this issue. They've told me that only mid-production Job 2 trucks actually included this feature. The mid-production job 2 trucks began coming off the assembly lines on or around 11-15-2010; mine wad built on 10-07-2010... According to the engineers, the vehicle cannot be upgraded to include this option without replacing the seat module and the instrument cluster. This sucks, not sure why my manual says it should be there...
Last edited by gldubzakjr; 08-04-2011 at 08:51 AM. Reason: Changed mis-typed dates from 2011 to 2010.
post #6 of 11 Old 07-27-2011, 02:31 AM
buletbob's Avatar
do you have the 2 switches on the drivers door to move the seat to its set position. should do the same thing except you have to hit the switch when you remove or insert the key.
TRADED
2007 F-350 Supper Duty King Ranch
6.0L Stock
Pioneer LCD Monitors In Head Rests
500 Watt 4 channel JL Audio Amp
250 Watt Mono JL Audio Sub Amp
JL Audio Speakers
10" JL Audio sub Center console
JL Audio Tweaters
Pioneer AVZ1
Custom Pin Striping
Hornet Alarm and remote start.
TRADED HER IN FOR A NEW 2011
NOW HAVE 2011 F-350 DUALLY KING RANCH
6.7L STOCK
GOLDEN BRONZE METALLIC CLEAR COAT WITH THE ADOBE BEIGE TWO TONE BOTTOM
buletbob is offline
post #7 of 11 Old 08-04-2011, 08:33 AM
WOW! Your truck was built in the FUTURE! Where can I get one from the future with all the bugs worked out of them.
Micheletti is offline
post #8 of 11 Old 08-04-2011, 08:53 AM Thread Starter
gldubzakjr's Avatar
Micheletti,
That's funny! When we enter a new year I have a hard time changing the year and as the year gets later I have a hard time typing the previous year. Good catch and thanks for pointing that out; I went ahead and edited the years to reflect 2010 instead of 2011... I too would love a future built truck; make it a King Ranch this time; the leather makes all the difference!
post #9 of 11 Old 08-05-2011, 07:30 AM
mor4wd's Avatar
Somebody tell me why it's a bad idea to post your VIN. It's not like it's your Social Security number. If anybody wants it they just have to look in the window of your truck. I'm sure if anything bad could be done with a VIN they the manufacturer wouldn't make it visible from outside the vehicle. Maybe I'm wrong.
As for the OP. Glad to hear you figured it out. I had my dealer sitting in my truck for 2 hours trying to get it to work a week after I bought it. I had just kind of forgotten about it until now.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #10 of 11 Old 08-06-2011, 07:29 PM
MDarrough's Avatar
They're watching you!!
Same here!! It has instructions in my manual (truck built 7/10), but I can't figure it out.
Mark
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
