Dash lights - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
post #1 of 8 Old 04-06-2011, 06:44 PM Thread Starter
Bavanew's Avatar
Quoted: 2 Post(s)
Dash lights
Hello!
I'm just curious if this is happening to everyone else, or just me??
When the DRL are on, the dash lights are nice and bright when set to the max setting. However, when the headlights go on, the brightness of the dash lights decreases by at least 40%-50%.
If you are also experiencing this, have you figured out a way to get the brightness to go back up to full capacity?
Thanks,
Blair
Bavanew is offline
post #2 of 8 Old 04-06-2011, 06:49 PM
DieselSteve's Avatar
Same thing happens with mine
DieselSteve is offline
post #3 of 8 Old 04-07-2011, 04:18 AM
sagebel's Avatar
Quoted: 10 Post(s)
I cover the sensor in the middle of the dash. I don't have DRLs so it may be different.
2014 CCLB 4x4 Lariat Ultimate
sagebel is offline
post #4 of 8 Old 04-08-2011, 11:54 AM
mor4wd's Avatar
Covering the sensor would only force the headlights to come on, hence dimming the lights. I don't have DRLs but why would you want your dash lights to stay bright at night. It only dims them when it senses the ambient light is below a certain level so it dims them so as to avoid blinding you and decreasing your night vision.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #5 of 8 Old 04-08-2011, 06:10 PM Thread Starter
Bavanew's Avatar
Quoted: 2 Post(s)
I hear what you're saying about being blinded, however, I should be able to decide for myself if the lights are too bright for my liking. If a driver cannot determine whether it's too bright for his or her eyes, which would make it unsafe to drive at night, then that person should not be driving.
I personally would not have it set to the brightest setting when it's completely dark out, but I would certainly have it a lot brighter than what it's governed to. My past few vehicle were never that dim, but, if there's no option to adjust this, then I'll have to live with it!
Not the end of the world, just little things that would be nice to have control over.
Thanks for the replies!
Cheers,
Blair
Secondly,
Bavanew is offline
post #6 of 8 Old 04-10-2011, 07:41 PM
mor4wd's Avatar
Maybe a stupid question, but have you adjusted the brightness of the dash lights up once the headlights come on. The computer remembers both settings and I believe you can only adjust the night lights once the sensor thinks it's dark.
mor4wd is offline
post #7 of 8 Old 04-17-2011, 04:34 PM Thread Starter
Bavanew's Avatar
Quoted: 2 Post(s)
No, not a stupid question, as we sometimes miss the simplest of things....
But, I did try that, so that's not the problem!
Thanks anyway!
Bavanew is offline
post #8 of 8 Old 05-02-2011, 09:55 AM
I'm not 100% on this but I know it happens on my 05' F150 and I believe the reason behind it is that when your main headlights come on the truck assumes it's dark out and dims the dash to compensate for the lower ambient light. It assumes there isn't glare making the dimmed dash just as easy to read. I may off interpreted the question wrong. Is this what you where wondering?
Damcnutt is offline
