no heat on remote start - Ford Powerstroke Diesel Forum
6.7 Powerstroke Interior Discussion (2011-2016) 6.7 Powerstroke Interior Discussion
 1Likes
post #1 of 16 Old 11-17-2016, 02:46 PM Thread Starter
jayhawk238's Avatar
Quoted: 3 Post(s)
It is starting to get cold where I live in Idaho, 22 this morning, and when I use the factory remote start on my 2011 the heater is not coming on as the owners manual says it should. Has anyone had this problem? And if so what was the fix?
2011 Ford F-250 Lariat 6.7 Power Stroke Short Bed with a Fifth Wheel Hitch to pull my 30 foot 2016 Wildcat MAXX Travel Trailer
I learned everything I needed to know about Islam on September 11, 2001
I don't have a anger management problem. I just need people to stop pissing me off!
jayhawk238 is offline
post #2 of 16 Old 11-17-2016, 09:34 PM
This may be way off but have you checked what you have "my temp" set at? I know whatever you have that set to then the truck should adjust the temperature to that degree depending on if it needs to run the a/c or heat...
BSTN is offline
post #3 of 16 Old 11-19-2016, 07:42 AM Thread Starter
jayhawk238's Avatar
Quoted: 3 Post(s)
Manual says no to that
The manual says that no driver settings will work during a remote start. But Thanks for your reply.
post #4 of 16 Old 11-19-2016, 08:16 AM
Thats weird cause I remote start mine every time I start the truck. The temperature inside the truck, including the heated/cooled seats, always goes to "my temp" regardless of what it was set to before I turned the truck off.
BSTN is offline
post #5 of 16 Old 11-19-2016, 06:38 PM
09SDLariat's Avatar
Quoted: 10 Post(s)
Garage
I noticed my 16' XLT doesn't give full fan when on remote start.
New:2016 F-250 XLT,6.7 Diesel, Bone stock,
Sold: 2009 F-250 Lariat, Bone stock, BFG All Terrains
Sold and Missed: 2003 F-150 2 WD Super Cab, Step side. BF All Terrains. "Grandpa's Truck"
Work:2011 Chevy Express 3500 6.0L, Custom roof rack.
Companies: 2000 E-450 500,000mi
09SDLariat is offline
post #6 of 16 Old 11-21-2016, 09:28 AM
As I understand it, the system will heat or cool as necessary to reach the "my temp" setting when you use the remote start function.
The statement in the book about "no driver settings work" means no changes can be made to settings (knobs and buttons) while in remote start mode. You have to put the key in run position to make changes.
2016 F350 CCLB SRW
Don-T is offline
post #7 of 16 Old 12-30-2016, 02:08 PM
Quoted: 48 Post(s)
Took me a while to understand this. "My temp" being a setting in the system, not the last temp you used via the knob.
And I've decided it needs to be set to auto. Is that right?
But I'm in Texas and we freak out and worm our trucks if it's 45*.
Blah blah blah
CJATE is offline
post #8 of 16 Old 12-30-2016, 02:42 PM
Quoted: 77 Post(s)
yes,, set it to AUTO.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #9 of 16 Old 01-07-2017, 01:21 AM
Quoted: 37 Post(s)
Not sure if 10 mins of idlng gets enough heat to provide any warm air from the vents...
heleonardman likes this.
wchain is offline
post #10 of 16 Old 02-09-2017, 11:03 AM
Tim250's Avatar
Quoted: 13 Post(s)
So I need to look at the "my temps" setting. When its cold and I work nights I set the heater and fan to full blast so that when i get back to the truck and start it remotely, its blows hot, but I have never been able to get the seats to remember a hot or cold setting. once I get in I then turn the seats to hot or cold. You guys saying I need to set in auto or on the "my temps" setting, to get the seats to respond?
2013 F-250 CCSB Fx4 3.55 Lariat, 17x9 -12mm Fuel Hostage on 315/70R17 Nitto terra grappler g2's, Weather Tech mats, Ellis light bar w/ 8" KC HID's, Carli 2.5" Lift
Tim250 is offline
