Question about max tire size with lift. - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 3 Old 08-14-2014, 05:09 PM Thread Starter
lowmpg's Avatar
Quoted: 33 Post(s)
Running a 6" Zone lift, the recommended tire is a 37x12.5 with 4.5 backspacing and a 0 offset. Can I run a 38" tire? Or, could I run a 37x13.5 - if so, what kind of offset should I look for? I was thinking a 20x9 with 4.5 backspacing and a -12 offset would work with a 37x13.5...thoughts?
2013 F350 No Limit EGR Delete, DPF delete, Gearhead Tunes, aFe Momentum intake, Zone 6" lift, 37x13.5x18 Open Country MT, HID lights, 20" Rough Country LED bar, Flo Pro and Banks pipes, 17mpg
lowmpg is offline
post #2 of 3 Old 08-14-2014, 07:20 PM
POWERCHOKER
Dantron's Avatar
I ran 37x13.5's and 20x10's on 6 inches of lift and had no problems. They tend to under-rate the recommended size for wheels and tires. I think you should be fine with 37x13.5's and -25 offset with 4-5 inches of backspace, which is what usually comes with 10 inch wide wheels.
Dantron is offline
post #3 of 3 Old 08-15-2014, 01:23 AM
Ramathorn's Avatar
Quoted: 2 Post(s)
6" lift, 37x13.5 Toyo MTs on 20x10 with -12 offset and 5" back spacing. Slight trimming on firewall side of fender liner but that's it, with no rubbing.
2014 F250 6.7 Platinum CCSB
6" ProComp Stage 2 lift, ProRunner shocks
20x10 Fuel Krank, 37x13.5 Toyo MT's
SCT X4 w/5 Star "tow tune"
Ramathorn is offline
