4" flo pro delete pipe - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 15 Old 08-13-2014, 04:45 PM Thread Starter
ucpa111's Avatar
Just looking for input on how to mount. I have the long bed crew cab. The stock system has a down pipe to the DPF section. This connects to a straight section of pipe. This then connects to the rear section of pipe that goes over the axle and to the tips.
I have the 4" two piece delete pipe + a 51" donaldson to install.
If I simply remove the DPF section, I'd have cut most of the straight section of the rear delete section of pipe away before installation. However, I am worried about NO hangers being present and the suspended length being too long.
I am curious if others have found a solution. It almost looks like I could remove the DPF section AND the stock straight section behind it. The Flo Pro system MAY then be able to use a stock hanger present at the rear of the DPF. The issue is that the donaldson will be located forward near the down pipe. I'd have to cut the delete section in half or better that connects to the down pipe. It gets tight in that area with the frame/etc.
Just curious if any long bed folks have skinned this cat successfully. Thanks in advance.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #2 of 15 Old 08-13-2014, 07:39 PM
Quoted: 12 Post(s)
I have the full 4" DP back exhaust, but similar layout. The straight section uses the front hanger and the next one used is back just before the axle. There is plenty of support between these two points.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #3 of 15 Old 08-13-2014, 09:33 PM
The way the 4" Flo Pro pipe is bent on my '13, the pipe is closer to the frame. I tried adjusting the fitting at the downpipe, but it wouldn't work any other way. Does anyone have pics of the front part of the pipe near the downpipe connection? The only reason I mention this is because the large diameter of the Donaldson may prevent it from being under the cab if the pipe located like mine. It opens up at the front of the bed where the frame bends upward so it would easily fit in the extension pipe section on the CCLB.
2013 F350 Lariat Ultimate FX4 CC LB SRW
jetskier is online now
post #4 of 15 Old 08-15-2014, 05:22 PM Thread Starter
ucpa111's Avatar
Ok…to install the delete pipe, do I need to pull the down pipe off? I cannot seem to reach the top flange bolt that connects the DPF system to the down pipe. Any ideas?
Is it easy to reinstall the down pipe if removed - by accessing underneath? I see what appears to be one bolt up top that looks like it needs to come off in order to remove the down pipe.
Thanks for any assistance.
THIS THING ROCKS!
ucpa111 is offline
post #5 of 15 Old 08-15-2014, 05:41 PM
Quoted: 3 Post(s)
You don't need to remove the down pipe. You just have to bend and reach that flange bolt from underneath. I was able to get that one with a long extension and wobble on my ratchet.
Deerhunter4 is offline
post #6 of 15 Old 08-15-2014, 05:45 PM Thread Starter
ucpa111's Avatar
Thanks. I think I am going to need to buy a flex extension.
THIS THING ROCKS!
ucpa111 is offline
post #7 of 15 Old 08-16-2014, 05:59 PM Thread Starter
ucpa111's Avatar
Job is done. DPF is heavy.
Thing sounds like I wanted and performance is improved as well. Thanks for all the input. Happy with the results! I took a 60 mile round trip that used to be 18.5mpg and it's showing 22 on the lie o meter. When I hand calc, we shall see. But that is pretty cool.
THIS THING ROCKS!
ucpa111 is offline
post #8 of 15 Old 08-16-2014, 06:43 PM
Str8Ugly's Avatar
did you use jack stands to hold the dpf while taking it off?
2011 king ranch f350 cclb 4x4, 6" lift, 20x10 fuel mavericks, 35" toyos, billet grille, ranch hand rear bumper, SCT X4 with PIP tunes, Sinister egr delete, flopro dpf delete pipe
2002 f250 ccsb 4x4
6" pro comp lift kit, 20x10 eagle 064's, 35" trail grapplers, 2007 front clip, Harley Davidson Headlights, Bull nose bumper, Ranch Hand Rear Bumper, dfuser harness, 6637 air filter, straight exhaust, foil delete
Str8Ugly is offline
post #9 of 15 Old 08-16-2014, 06:57 PM
Quoted: 3 Post(s)
Good job. I noticed that after deleting that my lie o meter is dead on. Always within .1 or .2 Mpgs.
post #10 of 15 Old 08-17-2014, 04:46 AM Thread Starter
ucpa111's Avatar
I used some ratchet straps. It helped with supporting the weight and I could gradually let it down. It also helped with the installation of the new Donaldson. I stretched the ratchet from running board mount to driveshaft and made a swing I could adjust up and down.
THIS THING ROCKS!
ucpa111 is offline
