Strange Buzzing After MiniMaxx Install - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
 1Likes
post #1 of 15 Old 08-12-2014, 10:11 PM Thread Starter
So I just installed my MiniMaxx with a non-delete tune. Went out for a drive and did the transmission re-learn. Very happy with the H&S performance (even in the non-delete trim).
The odd thing though is after I get home and shut off the truck and get out, I hear a humming which sounds like it is in the engine compartment along with a periodic buzz. The Buzz is about 1 second every 10 or 11 seconds. It does it for about 2-3 minutes and then there is a noise like a valve moving and all goes silent. The truck didn't do this before the H&S. Can anybody tell me what it is and if it's normal?
2012 F-350 Lariat CC SRW 4x4
Leveling kit with 35" Nitto Trail Grapplers
EskimoPie is offline
post #2 of 15 Old 08-12-2014, 10:22 PM
Ryan2012F350's Avatar
Garage
Pretty sure that's normal, mine did it not deleted and deleted.
I cant remember what it is (I read it somewhere) but your good I think.
2012 F350... Problems so far: Rear pinion seal, rad split, U-Joints, Waste gate tubing TSB.
4.5" Carli Lifted, 2.5" Kings, 37" Toyoed, Carli bagged, Wireless compressored, 5th hitched, rigids on both ends, slip tanked, titan tanked, upfittered, 12v pumped. Last truck I'll ever own.
Ryan2012F350 is offline
post #3 of 15 Old 08-13-2014, 07:02 AM
I'm pretty sure it's an actuator for the EGR. Anyone confirm?
14' F350 Platinum SRW - Stock - 27k miles
Asleepz is offline
post #4 of 15 Old 08-13-2014, 10:07 AM
Quoted: 3 Post(s)
That's what I've heard too. The sound is coming from near the turbo so it makes sense. I also heard if you press the brakes after the truck is shut off the sound will stop. I haven't tried that yet. I only hear it in my garage where it's quiet.
2013 F250 6.7 PSD
Crewcab FX4 6.5 ft bed
Factory 18" Michellins 3.55 gears
DPF and EGR delete 51" muffler
Punch it Performance tunes
Deerhunter4 is offline
post #5 of 15 Old 08-13-2014, 10:11 AM
HighHP's Avatar
Poke your head under the fuel tank when you shut it down and see if its coming from there maybe, DEF tank purges the lines after you shut the truck off so the little pump cycles
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #6 of 15 Old 08-13-2014, 01:13 PM
mor4wd's Avatar
The valve noise is the EGR Valve. You can duplicate the noise if you operate the plunger by hand.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #7 of 15 Old 08-13-2014, 01:42 PM Thread Starter
Cool, thanks for the info guys. Guess I should just get around to installing my No Limit EGR delete and be done with it.
post #8 of 15 Old 08-13-2014, 02:37 PM
Quoted: 3 Post(s)
My EGR is blocked and unplugged and I still hear it. Sounds like the waste gate solenoid that others have mentioned to me.
2013 F250 6.7 PSD
post #9 of 15 Old 08-13-2014, 03:09 PM
mor4wd's Avatar
I could be wrong. Mine truck doesn't do it anymore and I only have the EGR disabled.
mor4wd is offline
post #10 of 15 Old 08-13-2014, 07:15 PM
Quoted: 18 Post(s)
mine still does it with the egr deleted. truck has a damn mind of its own. its definitely nothing to do with the egr .
jayz likes this.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
