5" Exhaust w/ Air Bags - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 14 Old 08-06-2014, 10:47 PM Thread Starter
Any of you deleted guys have any clearance issues running 5" exhaust with air bags? Was also curious if I could run dual exhaust with bags... Search didn't turn up much of anything. Any info would be appreciated.
Schwab is offline
post #2 of 14 Old 08-07-2014, 04:51 AM
Quoted: 4 Post(s)
I'm running 4" with air bags and have plenty of room left so I think 5" wouldn't be An issue for me. You should have some room for adjusting the exhaust at least a little. Good luck.
2013 F250 6.7 PSD
Crewcab FX4 6.5 ft bed
Factory 18" Michellins 3.55 gears
DPF and EGR delete 51" muffler
Punch it Performance tunes
Deerhunter4 is offline
post #3 of 14 Old 08-07-2014, 04:55 AM
Heavy_GD's Avatar
Quoted: 867 Post(s)
Feedback Score: 3 reviews
over the leaf or under the rail?
If anything I would think depending on your lift you may hit the leaf.
GD - 06 CCSB FX4 Lariat
Originally Posted by G8orFord View Post
My magic wand broke a few years back when my crystal ball fell on it. Ruined the ball too. So we're going to have to figure this one out another way. YOU NEED A MONITOR or at least a good scanner.
Heavy_GD is offline
post #4 of 14 Old 08-07-2014, 05:50 AM
Ryan2012F350's Avatar
Garage
My setup clears with lots of room. Carli 4.5" plus Carli bags with a Flo-Pro 5"
2012 F350... Problems so far: Rear pinion seal, rad split, U-Joints, Waste gate tubing TSB.
4.5" Carli Lifted, 2.5" Kings, 37" Toyoed, Carli bagged, Wireless compressored, 5th hitched, rigids on both ends, slip tanked, titan tanked, upfittered, 12v pumped. Last truck I'll ever own.
Ryan2012F350 is offline
post #5 of 14 Old 08-07-2014, 10:29 AM Thread Starter
I've got the AirLift bags that mount under the frame rails. I think after looking at it 5 inch should fit- there is some sort of resonator on the stock pipe approx 5" in dia next to the bag now, and it clears it ok.
Do you lose the spare tire going with duals? Doesn't look like there is much room with the spare in there- if I have to lose the spare I might try something like this- please forgive me for the Dodge pic but the exhaust is what I'd like to do if I can't keep the spare tire.
5" Exhaust w/ Air Bags-imageuploadedbyag-free1407436073.845481.jpg5" Exhaust w/ Air Bags-imageuploadedbyag-free1407436122.096278.jpg
Schwab is offline
post #6 of 14 Old 08-07-2014, 11:43 AM
Hey Ryan2012F350. Exactly which exhaust from Flo-pro do you have? I have a 4.5" pintop kit and the only reason I don't have carli bags is because they told me it would not work with a 5" exhaust. Any more info on your setup? I really want the carli bags but am afraid they wont fit.
Thanks
cc2cuz is offline
post #7 of 14 Old 08-07-2014, 11:45 AM
Garage
Thanks
Same as you man, Carli Pintop 4.5" Lift, Flo-pro Aluminized 5" no muffler, fits great, doesn't even come close to being an issue with the Carli Bags.
Get the bags... you'll never look back.
post #8 of 14 Old 08-07-2014, 05:01 PM
Same here... 5" pipe with air bags. Plenty of room.
Sent from AutoGuide.com App
14 F250 CCSB
secstang03 is offline
post #9 of 14 Old 03-24-2015, 09:32 AM
Are you guys seeing any heat issues with the rubber on the bags? I have a 5" down pipe back Flo-Pro. Getting Firestone bags installed and was warned about heat issues with the exhaust in such close proximity to the bags (i.e. Melting the rubber). 2011 CCSB F250. Anybody seeing this?
AC '11 6.7L is offline
post #10 of 14 Old 03-24-2015, 04:58 PM
I Am Canadian!
dsmracing1's Avatar
Quoted: 14 Post(s)
Garage
I have the firestone airbags with a 5" flo pro with just a 5" rear block for a lift in the rear. No issues with heat since the firestone kit comes with a heat shield to shield it from the heat. You will be good to go!
2014 F-350 Platinum 4x4
Ready Lift 3.5" on 36" Tires/H&S Midwest Tuned/OUO/No Limit Fabrication/Fox/Flo Pro/Full Midwest 65.5 Streetmax Kit
500@The Wheels (New Results Coming)
"The Work Truck"
dsmracing1 is offline
