Fuel additive question - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 14 Old 07-09-2014, 07:56 PM Thread Starter
After doing a DPF and EGR delete is it safe and a good idea to use a fuel additive to add additional lubrication?
Fuco12 is offline
post #2 of 14 Old 07-10-2014, 07:27 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
My 13 was deleted for 15k before trading it in for my 14 which has been deleted for 3k and ive run Motorcraft cetane booster in both almost every tank. Also helps with super rich smell from tailpipe due to the fact that it helps give a more complete burn .
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #3 of 14 Old 07-10-2014, 08:56 PM
texaslimeaide's Avatar
Deleting the EGR and DPF doesn't change the fact that ULSD isn't lubricated enough for our pump and injectors. Keep using it.
13' CCSB FX4 6.7, 17"MB wheels, Cooper oversized all terrains, Amsoil 15w40 Diesel/Marine oil with Ea Oil Filter.
2013 6.7 Powerstroke F250 XLT Crew Cab 4X4 First Owner. Amsoil OE 15W40 Diesel Motor Oil. MB Wheels and Cooper 34.5" x 12" tires.
SOLD!! 2006 F250 Lariat Crew Cab 4x2 88k miles, 4" Diamond Eye Turbo Back Exhaust, Amsoil 15W40 Synthetic Heavy Duty Diesel and Marine Motor Oil, Ea Amsoil 15k oil filter, Oil Charge Systems Amsoil Bypass Filter, SCT TSX (no custom tunes yet), Sinister Coolant Filter Kit, Zoodad Mod, Custom Diesel EGR Cooler Delete.
texaslimeaide is online now
post #4 of 14 Old 07-11-2014, 03:59 PM Thread Starter
I agree but I was trying to find out what everyone else was using. I've heard of people using 2 cycle oil, Lucas, and many other things.
Fuco12 is offline
post #5 of 14 Old 07-11-2014, 04:08 PM
Opti-Lube is the best.
lizardking is offline
post #6 of 14 Old 07-11-2014, 09:04 PM
billybadd's Avatar
I use power service diesel kleen, silver bottle.
billybadd is offline
post #7 of 14 Old 07-12-2014, 07:04 AM
HighHP's Avatar
I use Howes. I find all additives are pretty much the same, I get Howes cheap through work so I run it, also nice if your in a cold climate over the winter, Howes guarantees you won't have a tank of fuel gel with there stuff or they will pay to have vehicle towed and cleaned out.
Also run a little 2 stroke every once in a while, only do this once deleted though.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #8 of 14 Old 07-12-2014, 07:09 AM
post #9 of 14 Old 07-12-2014, 10:32 AM
Senderofan's Avatar
I've been using Opti-Lube XPD in my rig.....for nearly 40K miles....I've been extremely satisfied with the product. I don't use anything different when we're well below zero in the winter and the truck fires up quickly with vey minimal smoke. The rig before this one....I used a combo of a cetane booster and added a cold flow improver to the mix when temps fell below zero....this combo didn't seem to perform as well as the Opti-Lube...but this is just my experience, YMMV.
Wayne
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #10 of 14 Old 07-12-2014, 02:34 PM
It's all I use as well.
