CEL with code PO191 - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 12 Old 06-17-2014, 03:26 PM Thread Starter
CEL with code PO191
I have a 2011 F-450 pickup. Truck has 102909 miles on it. I did the full egr delete, 5" downpipe back without muffler and h&s mini max about 1000 miles ago. I was playing with the differnt gauges on the mini maxx and when i use ICP I can kill the truck and crank back up and get code po191 fuel rail pressure sensor circuit range/performance. Well I cleared the code and set gauges back to what I had them on and it didn't come back on. This morning I noticed while idling I had about 100 rpm lope. So I killed the truck and restarted and it turned over and started but was at such a low rpm that the starter stayed engaged until I touch the throttle then it went to normal. Did this twice. I put it back to stock on the h&s and then redownloaded the deleted tune. It cranked fine but gave me this code again. Rushed to the ford house and bought new fuel filters to have somewhere to start and put them on. So far so good till I killed truck then started 10 min later and got code again. I keep it set on performance. And it won't throw code while driving only if I kill it then crank back up. And not every time either. Anybody had this happen?
Superduty81 is offline
post #2 of 12 Old 06-24-2014, 07:39 AM Thread Starter
Just an update. Drove from west tx to arkansas and back this weekend running 85 and 90 mph with no troubles at all. About 5 min ago running 15 mph truck just died with no codes gave me a crank but no start for about 10 min. Then started and had the same code come up.
post #3 of 12 Old 06-24-2014, 09:58 AM
Bryce18's Avatar
Quoted: 17 Post(s)
Are you running out of box h&s tunes or custom mcc tunes from another vendor?
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #4 of 12 Old 06-24-2014, 10:10 AM Thread Starter
Out of box h&s. I've put around 100 miles on her since this happened this morning. Stop and go traffic, interstate and shutting off and starting agian and has not happened again.
post #5 of 12 Old 06-24-2014, 02:51 PM
Bryce18's Avatar
Quoted: 17 Post(s)
Have you tried calling or emailing H&S? If no response I would maybe go ahead and purchase a mcc unlock code and a custom tune from another vendor such as SPE, Gearhead etc.
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 12 Old 06-24-2014, 03:51 PM Thread Starter
No I haven't directly. I've posted in their forum exactly what I posted here with no response. I'll give them a call tomorrow. Thanks for the help.
post #7 of 12 Old 06-25-2014, 10:26 AM Thread Starter
Talked with h&s tech threw email. They said they have 3 6.7 test trucks and none have experienced what I have with trying to moniter rail pressure and getting code. And to take to ford for diagnostics but I was under the impression that they couldn't hook up to the computers on these things with aftermarket toons without frying computer. Could someone explain to me how that works.
post #8 of 12 Old 06-25-2014, 12:24 PM
Bryce18's Avatar
Quoted: 17 Post(s)
Is your dealer tune/ delete friendly?
If so just take truck to dealer unplug mini maxx, have them hook there computer up and check codes. As long as they don't update or reflash the trucks computer with the h&s tunes installed all should be fine.
If they say they need to update or reflash the trucks computer, 1. plug your h&s back in,
2. return the truck back to stock.
4. Unplug h&s tuner
5. DO NOT START TRUCK"
6. have them update/ reflash truck computer.
DO NOT START TRUCK"
7. Plug h&s back into truck, instal delete tunes.
8. You are good to go and can start truck.
You can return trucks computer and tune back to stock without replacing stock exhaust and components as long as the truck is not started. But do not start truck until the delete tuning is loaded back onto truck computer.
If your dealer might void your warranty for tuning and deletes, put all stock exhaust and components back on, use h&s to put computer back to stock, then take to dealer and have fix.
Sorry if I am confusing you. I can clear up better if needed.
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #9 of 12 Old 06-25-2014, 01:16 PM Thread Starter
I understand what your saying. And thanks for clearing that up. I feel like it's a problem with my mini maxx and not my truck because if I use the rail pressure as one of my gauges I'll get that code every time I start the truck. But if not it's hit and miss as to when it will do it. I guess the next time it comes up I'll call the ford place and let them look at it. Sure hate that though.
post #10 of 12 Old 06-25-2014, 01:34 PM
Bryce18's Avatar
Quoted: 17 Post(s)
Yeah I know what you mean about going to the dealer. I'm one of the lucky ones that have a friendly dealer. They do all my services and dont care about mods.
Have you tried taking h&s tuner out of truck and updating it on your computer then uploading back to truck? Do you know which firmware and update #s you are currently running?
In your h&s menu you can look these up.
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
