Need help from u smart guys??? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 8 Old 06-02-2014, 08:22 PM Thread Starter
Hey guys I helped my friend delete his 2011 6.7 today.. We took it for a ride and runs very well for awhile.. then he got on it a couple times the turbo like flutters or something.. Almost like over boosting maybe? It only does it when he gets on it hard.. like around 30 mph but something isn't right? could it be bad turbo? truck only has 15k on it. thanks
taz1 is offline
post #2 of 8 Old 06-02-2014, 09:00 PM
Quoted: 19 Post(s)
possible. the fuel and boost may be exploiting what was prolly a very un-noticeable problem before.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
post #3 of 8 Old 06-02-2014, 09:11 PM
PROUD AMERICAN!!!
Rattlesnake18's Avatar
Quoted: 563 Post(s)
Feedback Score: 6 reviews
The title says the OP needs help from a smart guy and I'm not sure you fitt the requirements bud.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 8 Old 06-02-2014, 09:14 PM Thread Starter
hmmm so even if it was fine before it still could be a sign of bad turbo??? thanks
taz1 is offline
post #5 of 8 Old 06-03-2014, 10:38 AM
Carli'd6.7's Avatar
You need to give more details to me is sounds like a trans issue what tune are you using what boost #s are you seeing did you relearn the trans is it more of a feeling or a noise what's your rail pressure at come on man !!
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #6 of 8 Old 06-03-2014, 11:10 AM Thread Starter
It's not the trans. Yes did relearn and drove about 400 miles since. It's like it doesn't like all the boost at once.. Think he seen 36 psi. Someone said there a tsb from ford on this issue ???
taz1 is offline
post #7 of 8 Old 06-03-2014, 11:15 AM
Carli'd6.7's Avatar
Yea that's def a lot of boost what is the wastegate or spring rated too that might be your issue rite there try loading a street or tow fueling tune and see if you have the same issue or just have your tune MCC 'd to max out slightly lower
post #8 of 8 Old 06-03-2014, 11:55 AM
Quoted: 19 Post(s)
If anything the fact that turbo saw 36 psi is a good chance it oversped . If you knew how fast these turbos spun you'd prolly think differently about diagnosing this. It's not a wastegate issue .
H&S Motorsports
BMF Wheels
Icon Suspension
800-581-8986
bigrpowr is offline
