Removing def tank pointers - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 18 Old 05-27-2014, 08:53 AM Thread Starter
Bryce18's Avatar
Quoted: 10 Post(s)
After about 2.5 years of being deleted I'm planning on removing my def tank to wash out due to the fact it was about half full when I deleted. Then I will be putting back on truck.
Does anyone have any tips or advice of removing the tank. I can't seem to find very much info or any instructions.
After I do mine I'll have a buddy's truck to do as well
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #2 of 18 Old 05-27-2014, 12:23 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
If I remember rite there is only 4 bolts holding it in and the lines that used to go to the exhaust are just quick connects and the feed hose is just a worm clamp I had mine out in 15 mins or so and its just sitting on the side of my house smelling like a farm on hot days
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #3 of 18 Old 05-27-2014, 12:36 PM Thread Starter
Bryce18's Avatar
Quoted: 10 Post(s)
I'll be tackling the project in the next few weeks. I haven't looked yet but does it have brackets like the ones that hold the fuel tank?
After removing bolts will the tank lower enough to reach the lines and feed hose?
Or before lowering tank do I need to remove feed hose from bed where filler cap is?
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #4 of 18 Old 05-27-2014, 03:46 PM
Carli'd6.7's Avatar
No its not like the straps holding the tank its more like a tub that the def tank fits in to if I remember correctly you can undo the lines and harness with no problem before dropping the tank
post #5 of 18 Old 05-27-2014, 09:46 PM
It also helps to loosen the skid plate at the back near the tank. That helped me alot while removing mine.
Horms07 is offline
post #6 of 18 Old 05-30-2014, 10:32 AM
Quoted: 3 Post(s)
How many gallons does it hold. Would it be posible to convert it to an auxillary fuel tank.
Storm95 is offline
post #7 of 18 Old 05-30-2014, 11:44 AM
HighHP's Avatar
I'm pretty sure 5.5 gallons. It's possible with a little pump to transfer the fuel from the tank to the main tank filler neck.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #8 of 18 Old 05-30-2014, 12:35 PM Thread Starter
Bryce18's Avatar
Quoted: 10 Post(s)
Thanks for the input guys. Might have time this weekend to tackle the job
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #9 of 18 Old 07-23-2014, 07:04 PM
DIGMAR's Avatar
Quoted: 17 Post(s)
How'd you end up with cleaning the tank? I'm doing my delete this weekend and want drain and rinse the tank. Only concern I have is the residual DEF in the pump somehow corroding or clogging up the pump over time. Only concerned for if/when I have to return to stock down the road that the pump will still work.
DIGMAR is online now
post #10 of 18 Old 07-23-2014, 09:11 PM
Quoted: 18 Post(s)
I would say warm water should be suffice.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
