Egr deleted now seems slow - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 9 Old 05-26-2014, 08:38 PM Thread Starter
raptorgabe's Avatar
Just got my egr deleted finally and seems like it takes a little longer to spool than before does this seem like it's normal whistles more though I checked everything and it all seems tight and put together right
2013 6.7 f350 tuxedo black platinum
2015 spe retro turbo kit
egr delete 5" exhaust
5" no limit intake
gearhead tunes
20x10 bmf fits 3" spacers
leveled
raptorgabe is offline
post #2 of 9 Old 05-27-2014, 12:53 AM
brockadams2002's Avatar
Did your egr cooler break? If so.. Did you clean your turbo?
2005 F-350 lariat , 6.0, crew cab, long bed, 8in Rize industries lift, 37in toyo MT on 22" Fuel rims. RCD EGR delete, "Zoodad mod."
brockadams2002 is offline
post #3 of 9 Old 05-27-2014, 05:51 AM Thread Starter
raptorgabe's Avatar
I installed the sinister delete kit so it's totally out of there now ? And I figured if it was a boost leak from the clamps or somethin it would be smokin a lot !
5" no limit intake
gearhead tunes
leveled
post #4 of 9 Old 05-27-2014, 07:45 AM
No, I don't believe it would smoke. What is your turbo psi?
post #5 of 9 Old 05-27-2014, 07:48 AM Thread Starter
raptorgabe's Avatar
I will see here in a min it pulls good but gettin there seems like a minute ! Maybe it's just me being paranoid il double check everything than see what te boost goes up to
5" no limit intake
gearhead tunes
leveled
post #6 of 9 Old 05-27-2014, 08:11 AM
When's the last time you changed fuel filters? When I did my egr delete. I cleaned the turbo, changed oil, fuel filters, cleaned mass air sensor. Cleaned EBP. Did the "zoodad" mod.
post #7 of 9 Old 05-27-2014, 08:42 AM
HighHP's Avatar
If one of the block off plates were leaking youd see the soot collect under the hood pretty quickly. I think you should be ok!
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #8 of 9 Old 05-27-2014, 04:45 PM Thread Starter
raptorgabe's Avatar
the damn intake elbow after the mas wasnt tight the hose was just on it so must have been suckin air ! tightened it up and is all good now !! i love it
5" no limit intake
gearhead tunes
leveled
post #9 of 9 Old 05-28-2014, 10:43 AM
HighHP's Avatar
Good catch. That one would be very easy to miss for the average person!
HighHP is offline
