Gear head trans tune quirks ?? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 28 Old 05-26-2014, 05:02 PM Thread Starter
Carli'd6.7's Avatar
Feedback Score: 6 reviews
So I know a lot of you purchased the gear head tunes because of the loads of positive feedback from Jcain and myself and I'm curious if anyone has found any weird quirks they don't like about it cuz I have a few. I've never experienced reverse or drive delays until i started using this tune ,sometimes as long as 7-8 seconds when changing direction . Also the cold engine harshness is worse than stock although the trans does hold gears longer I have experienced many parking lot speed shift flares . Am I the only one ? I'm going back to stock and just play with my +/- minus buttons for the time being because I have a few really heavy tows coming up .
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #2 of 28 Old 05-26-2014, 05:25 PM
POWERCHOKER
Dantron's Avatar
I haven't experience any yet. I'll pay closer attention to the reverse/drive delay and see if I notice anything.
Dantron is offline
post #3 of 28 Old 05-26-2014, 06:06 PM
None so far. A few harsh downshifts with tow haul on though.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #4 of 28 Old 05-26-2014, 06:28 PM Thread Starter
Carli'd6.7's Avatar
Ill probably give em a call tomorrow and see if there is anything they can do or maybe add some trans PSI at idle or something
post #5 of 28 Old 05-27-2014, 07:06 AM
garyfulton's Avatar
Theres a TSB out on the delayed trans. engagement. You might look that up and see if it fits your problem.
garyfulton is offline
post #6 of 28 Old 05-27-2014, 11:17 AM Thread Starter
Carli'd6.7's Avatar
I talked to Matt last night and he said its probably because the SPE and his trans tune aren't jiving rite because of engine load percentages which control shift speed and pressure so he re wrote my engine file email it to me last night I put 300 miles on it this morning with 5k on the bumper so far so good and ive so far seen a 1.2 MPG gain with this engine as opposed to my SPE tow file
post #7 of 28 Old 06-05-2014, 04:56 PM
POWERCHOKER
Dantron's Avatar
I know what you're talking about with the reverse delay now. I've noticed it several times since you started this thread. Before I kept thinking the truck was accidentally in neutral. Another thing I've noticed is when I need to quickly accelerate to miss a red light or pull out in front of traffic there will be a 3-4 second delay prior to acceleration followed by a huge pile of smoke. I remember the H&S performance tune being a bit more responsive in those situations.
Dantron is offline
post #8 of 28 Old 06-05-2014, 05:25 PM
Quoted: 18 Post(s)
Carli'd-
Are things still working better with the Gearhead engine/trans combo? If so, did running the combo solve all your complaints with the setup?
Dantron-
Are you running both the Gearhead engine and trans tunes or trans only? Just trying to research my options.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #9 of 28 Old 06-05-2014, 07:07 PM Thread Starter
Carli'd6.7's Avatar
No I'm not really fan I went back to SPE and stock trans tune and just use my buttons to literally tell the truck what to do . I also noticed the Gearhead tune has TONs of low end NO mid and Tons of top end . it was fun while it lasted haha I care more about my typewriter finally being gone then the money spent on that tune haha
post #10 of 28 Old 06-05-2014, 08:44 PM
POWERCHOKER
Dantron's Avatar
Originally Posted by Sterling6.7 View Post
Dantron-
I'm running both Gearhead tunes. The trans is definitely more responsive than stock when you get on it and it's pretty smooth and consistent when you drive normal. I like it overall. The only weird part is the mentioned shift delay to reverse. The performance tune is definitely more intense than the H&S performance tune. My only complaint is that sometimes it will pause and then unleash a ton of smoke when it does accelerate. I think the boost settings max out at 30 while my H&S tunes were set to 25. I haven't tried the Gearhead trans tune together with the H&S engine tunes yet.
Dantron is offline
