towing with H&S safe????? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 5 Old 05-02-2014, 08:41 AM Thread Starter
simple/6.7's Avatar
Im wanting to hear about using the tow tune while towing from anyone with experience. I have a 35' 5 er and just got an H&S and my 4 " exhaust. My previous truck was a 2006 6.0 tuned and eventually bulletproofed with all the obvious items and temps to watch. What im wanting to know is what do I need to watch on my 6.7 I never blew my gaskets or egr on my 6.0 because I knew what to monitor. I ran the 6.0 on an edge evo tow tune pulled a 35' gooseneck with anywhere from 5k- 12k loaded for almost 2yrs before I got sct tunes and studs and everyone says to not tow or tune a 6.0 if you want it to last. I did both so is the 6.7 safe to tow with while tuned ??
simple/6.7 is offline
post #2 of 5 Old 05-02-2014, 10:34 AM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
I haven't had any issue what so ever towing deleted I think you will be very happy just keep your EGTs under 1350 , keep an eye on your trans temps and take it easy off the line don't get into hard till the torque converter locks up in 3rd if using tow/ haul mode
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #3 of 5 Old 05-02-2014, 10:49 AM
WoodBoy's Avatar
There is nothing to be concerned with towing with a tuned 6.7.. If you had enough sense to tow fine with your 6.0 then you have absolutely no worries
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
http://www.powerstroke.org/forum/6-7...ustration.html
http://www.powerstroke.org/forum/6-7...round-2-a.html
WoodBoy is offline
post #4 of 5 Old 05-02-2014, 12:29 PM Thread Starter
simple/6.7's Avatar
What are safe temps and boost levels.
post #5 of 5 Old 05-02-2014, 12:56 PM
WoodBoy's Avatar
Boost levels would probably be around 26ish psi and if your Minimaxx is up to date you shouldnt have a problem. Oil probably around 220 I would start paying attention to it. EGT's you dont want to be doing a minute pull at 1300* but for the most part on the tow tune like I said you should be perfectly fine.
WoodBoy is offline
