Changing settings on my Mini Maxx....help - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 6 Old 04-20-2014, 08:39 AM Thread Starter
OK. I have a Mini Maxx on my 2013. Went to SPE a couple of weeks ago and deleted truck(9.500 miles). Love the Hot X tune but not so crazy about the mild/tow tune. Could someone walk me through the process of changing just the tranny tune? I want to keep everything else the same, just want to go back to stock tranny tune. Here it what I was told by another member, just want to be sure. Don't want to f*** up my DD. 1. Do not start truck 2. Go to install downloads 3. Go to import export MCC 4. Download custom tune 5. Select no for transmission 6.Pick SPE file for engine. Can't I just go in and change the tranny tune? Thank you in advance for your help.
DinoB is offline
post #2 of 6 Old 04-20-2014, 09:50 AM Thread Starter
Nobody can help?
DinoB is offline
post #3 of 6 Old 04-20-2014, 10:52 AM
Long Member
TMAG6.0's Avatar
On my H&S XRT Pro I didnt like the "Performance" trans tune either. What worked for me was to return to stock then reload the tune and select "Do not tune transmission" when that part comes up.
Now Im running the H&S "Street" Tune with the trans tune. I dont know if there is different trans tunes for the different power levels or if the trans is just learning how to handle the extra power. Either way its working for me on that power level.
You may need to just flash and reflash until you find the combination you like.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click HERE to save a childs life.
TMAG6.0 is offline
post #4 of 6 Old 04-20-2014, 11:13 AM Thread Starter
Thank you. So is the sequence that I listed above the correct way to do this? Sorry, never messed with this type of tuning before. Was used to my change on fly 6 position chip...............that was so easy................lol.
DinoB is offline
post #5 of 6 Old 04-20-2014, 11:27 AM
go to install download
select import/export MCC
select export files to SD card
when it prompts to tune the transmission or not, you can select yes if you want the H&S modified trans shifting or no if you want the OEM Ford trans shifting
once it has finished exporting the files, go to install download, select import/export MCC files. select load custom tune to truck
pick your SPE engine tune, and your F67TRANS file that you just exported and voila
drunk on diesel is offline
The Following User Says Thank You to drunk on diesel For This Useful Post:
DinoB (04-20-2014)
post #6 of 6 Old 04-20-2014, 11:28 AM
and now that I re-read your post and think about it, yes, if you have the option to "not" tune the transmission during your custom tune upload, if you select no, it will load the OEM tune. The flash process tunes the ECM and TCM every time
DinoB (04-20-2014)
