wicked wheel updates? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
 4Likes
post #1 of 45 Old 04-20-2014, 07:31 AM Thread Starter
Does anyone that has installed one have any updates on how its working out for you. I'm going to invest before too long and want to hear how yall are liking it so far
Horms07 is offline
post #2 of 45 Old 04-20-2014, 07:39 AM
HighHP's Avatar
Well my install is taking longer then I had planned. My wheel showed up just over a week ago but then I decided I might as well do my EGR delete while Im in there to make things a bit easier. So that brought me to needing to get my tuner, which didnt show up until a few days ago. Then I hooked up my tuner to see how it worked for deletes thinking I could pick which options to delete. Thats when I realized I couldnt just do the EGR delete to start, so now Im in the market for my DPF delete, which is probably going to take a week or 2. Ill be doing a good write up once I get everything all ready to go!!
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #3 of 45 Old 04-20-2014, 07:54 AM Thread Starter
I've been wondering what your hold up was Lol. That will bea good time to take care of all that. I'm looking forward to your write up and review.
Horms07 is offline
post #4 of 45 Old 04-21-2014, 07:07 PM Thread Starter
Anyone else
Horms07 is offline
post #5 of 45 Old 04-21-2014, 09:45 PM
Randy_270's Avatar
Quoted: 2 Post(s)
I'm gonna throw this out there, I was doing some reading on powerstrokearmy and a very smart person that knows diesel in and out pointed out a very good point. He said, and I quote, "Shaft speed slows down, but when it slows down the added volume trying to be compressed in the same area is going to make more pressure inside the housing than before which is providing a torque in the opposite direction of rotation... That will increase the normal force around the shaft potentially causing more bearing wear and shear stress than the bearing and shaft assembly were meant to handle...on top of the assembly not being balanced from the aftermarket wheel.
In summary the way I see it. May be wrong, may be right, just the way I see it with what I've learned thus far"
So a wicked wheel may benefit the stock turbo, or it could just aid in blowing it up... no one will know until they someone has run one for a long time.
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #6 of 45 Old 04-22-2014, 07:09 AM
HighHP's Avatar
Pressure won't have any effect on shaft wear because it's an equal force acting on all sides of the wheel. We know these housings can handle upwards of 30psi and that's not the weak point, slow down shaft speed and reduce wear thus extending shaft life. The pressure is controlled from the exh side so the truck sees stock back pressure and shaft speed but the wheel design is what's giving the slight boost increase.
Also these turbos are component balanced so changing the wheel has no effect on unit balance as long as the wheel comes balanced, which it does.
jayz, "Stroker 8" and Horms07 like this.
HighHP is offline
post #7 of 45 Old 05-01-2014, 07:10 PM
VT19's Avatar
Quoted: 21 Post(s)
calling all physics majors to the stage please!!!!!!!
2016 F250 Platinum FX4 (10/02/15)
SCT X4 tuner
Flo Pro full 5'' exhaust / no muffler 6'' tip
3'5 ready lift W/ Toyo AT 2 extremes on factory Platinum wheels
SOLD
13 F250 Lariat crew FX4
H&S MiniMaxx Race Tuner
5" FloPro race exhaust w/ muffler
S&B CAI
4" reddy lift
20x10 Fuel Cranks
Toyo M/Ts
N-Fab Steps
70 gallon fuel cell
Carhart seat covers
VT19 is offline
post #8 of 45 Old 05-03-2014, 04:01 AM
TampaSteve's Avatar
Feedback Score: 3 reviews
Have done 6 or them since January, all are running great. On the h&s tuned trucks it holds boost more consistent at 30lbs. Turbo noise does not change, definitely worth the money.
2012 F-250 6.7 CCSB
Spartan war hammer, wicked wheel II, S&B intake, 4" flow pro w/dual mufflers, rigid dually's, IPad in dash, JL stealth box under rear seat, Hertz HSK 165 front and rear, JL 450/4, 500/1, line x, roll x tonneau, Titan Tank, and coming soon 6" lift, American force 22x11 Recon SS wrapped in 37's.
TampaSteve is offline
post #9 of 45 Old 05-03-2014, 06:05 AM
HighHP's Avatar
Thanks for the update thats awesome to hear! I might just have to bite the bullet and install mine this set off work. Ill just have to pull the dpf off and run down pipe to nothing for a week
HighHP is offline
post #10 of 45 Old 05-04-2014, 07:03 PM
Has anyone put one on a completely stock truck with no tunes?
2011 F350 CCSB Lariat SRW
Readylift 2.5" leveling kit
Western SS MVP3 Plow
Hfd137 is offline
