6637 mod - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 5 Old 04-19-2014, 08:11 AM Thread Starter
Rodslinger's B1TCH
6637 mod
i was helping my brother out with doing the egr delete on his 2012 yesterday and we figured out that my 6637 style filter from my 7.3 will easily fit where the air box is. he's planning on putting one in his truck today.
can anyone see a reason not install one on this truck? he's going to hack the MAF sensor into the piece of PVC pipe between the filter and stock intake boot so that shouldn't be a problem.
steve604 is offline
post #2 of 5 Old 04-19-2014, 08:07 PM Thread Starter
Rodslinger's B1TCH
It ended up working out ok
ID:	275889   Click image for larger version
steve604 is offline
post #3 of 5 Old 04-19-2014, 08:35 PM
blue99stroker's Avatar
Quoted: 153 Post(s)
its gonna blow up, too much clean air.
lol jk looks good. hows does his truck like it. maybe ill do this to my grandmas 6.7
blue99stroker is offline
post #4 of 5 Old 04-19-2014, 09:20 PM Thread Starter
Rodslinger's B1TCH
He says he definitley hears a difference. I took it for a drive and heard nothing. With dpf delete, egr delete, 5" straight pipe and a 500hp race tune it makes about 5% of the noise of my 7.3 in the cab at idle. With that kind of power it's hard to tell if 10 hp was gained
We cut the stock pipe off top half of the airbox and attached it to the filter with a fernco coupling. His stock filter loked like it was going to be an expensive part so his filter replacements wil at least be cheap and easy.
I was surprised to see just how big the actual EGR was. Removing that opened up a lot of space on the engine.
steve604 is offline
post #5 of 5 Old 01-24-2015, 02:33 PM
WORM5932's Avatar
hey steve. hows this setup working out? I had a 7.3 with the 6637 and im thinking about doing it. id like to remove the silencer as well.
01 f250, nothin to write home about-GONE
08 f150 screw lariat-gone
11 f250 lariat
WORM5932 is offline
