Mini maxx install question - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 5 Old 04-13-2014, 06:01 PM Thread Starter
Right now I have my mini just running off obd port. The issue is the mini is always on this way. Is there any negative to running it this way?
Sulldaddy is offline
post #2 of 5 Old 04-13-2014, 06:46 PM
Long Member
TMAG6.0's Avatar
My CTS turns off shortly after the key is off, its just plugged into the port too. I would expect the Mini to do that as well. Does it stay on even after you leave the truck and lock the door?
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click HERE to save a childs life.
TMAG6.0 is offline
post #3 of 5 Old 04-13-2014, 07:02 PM
Quoted: 18 Post(s)
There is a thread on here from a couple weeks back that hits on this topic. I don't own a MM, but apparently there is a wire that needs to be spliced in that will turn this off with the key. I believe that the only downside to not splicing the wire is the possibility of dead batteries, but I could be wrong. Try searching and you will probably find it.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #4 of 5 Old 04-13-2014, 08:41 PM Thread Starter
Thanks, you are correct. I will do that this week for sure.
post #5 of 5 Old 04-14-2014, 09:26 AM
I am 99% sure it is the white with blue line. I will have to look next time I walk out to my truck.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
