Anyone running a 4.5 or 6" lift with only factory steering stabilizer? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 11 Old 02-22-2014, 07:33 PM Thread Starter
Quoted: 2 Post(s)
I am just wondering if you have any pull when braking.
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 11 Old 02-22-2014, 08:00 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
As long as your caster correction is good ( drop brackets ) you should have no problem at all I ran a 4.5 inch Icon lift with 20s w/35s for a long time with just the factory stabilizer and an adjustable trac arm and it was fine for the 6k I had it on . Most steering stabilzers with not correct any kind of pull when braking but a charged stabilizer such as a Carli or Fox and some of the better bilstiens will correct the right hand pull while driving that most toyo tires give you .
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #3 of 11 Old 02-24-2014, 11:25 AM
OCVeloMan's Avatar
Quoted: 114 Post(s)
Garage
I would be more concerned with tire size than lift height. I'm at 80K in my 06 with both 35" and 37" tires still on the factory stabilizer... It hasn't failed and I'm only still running it because we don't make a stabilizer for the 05-07
OCVeloMan is offline
post #4 of 11 Old 02-24-2014, 02:25 PM
Skyd Ram's Avatar
Quoted: 62 Post(s)
Unless the alignment shop put a ton of cross caster into your truck I would guess that you already have a right pull due to the Toyo's. If it only pulls to one side under braking (not diving on one side) I would guess that it could be a brake issue.
A stabilizer is mostly to turn out steering oscillation that you would feel as a shake in the wheel and to absorb some of the shock to the steering system when you hit bumps.
Although Dan has had good luck with the 80K mile factory stabilizer on his 07 I have seen the factory stabilizer on the 08+ trucks completely wore out with less than 30k on them when you run wider than factory tires.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
post #5 of 11 Old 02-25-2014, 07:18 AM
I've heard time and again, with the proper set up, you do not even need a stabilizer! I ran my 4dr Rubicon on 37's for awhile without a steering stabilizer just to prove the point that one is not needed to someone.
Might be a different story on these heavy trucks tho.
cmb396 is offline
post #6 of 11 Old 02-26-2014, 05:49 PM Thread Starter
Quoted: 2 Post(s)
I have no pull when driving, but my truck dives to the left when I brake.
Any ideas? I am taking it to the shop soon.
wreedPS is offline
post #7 of 11 Old 04-29-2014, 10:26 AM Thread Starter
Quoted: 2 Post(s)
Still have this issue even have brakes have been serviced I am thinking it is a alignment problem or bad parts. Any ideas?
Truck pulls to left when braking
wreedPS is offline
post #8 of 11 Old 04-29-2014, 01:18 PM
rstarr harley's Avatar
I had the same problem with my 2011 f350. I had a Carli 4.5 on it with 35in toyo M/t's. It would only pull under braking. I just so happens i own a brake and alignment shop and we went through the truck 10 times over and couldnt ever find anything to fix it. I have a 2013 now with the exact same kit but with 37in toyo m/ts and the trucks drives perfect. Im starting to think it was a tire issue on my 2011. If its a alignment issue its going to pull at all times not just under braking. I would also check if your alignment shop used castor bushings in it. I had a shop put way to big of castor bushing in it. I pulled it and put a smaller one in and it helped some.
2013 F250 Plantinum Carli 3.0 Dominator 37in Toyo M/T's
18X9 BMF Novakane stealth's
2011 F350 KING RANCH
Carli 2.0 4.5in w BMF 20X9 Novakanes 35in Toyo M/T'S
2009 F250 HARLEY DAVIDSON
2004 F250 HARLEY DAVIDSON
12 inch Icon With 20in Mazzi hulks with 40in Toyo M/T'S
2002 F250 LARIAT
18in custom lift with 44in Super swampers
2001 F350 LARIAT
rstarr harley is offline
post #9 of 11 Old 04-30-2014, 01:05 PM Thread Starter
Quoted: 2 Post(s)
the more and more I drive it, I believe it is a alignment issue and the hard braking just exaggerates it more.
wreedPS is offline
post #10 of 11 Old 04-30-2014, 01:13 PM
Not sure if you have checked the track bar or not. Make sure everything is right with that. Did your alignment shop give you a print out of what your castor settings were?
2002 F250 LARIAT
2001 F350 LARIAT
