H&S mini maxx help??? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 9 Old 02-07-2014, 01:00 AM Thread Starter
DaddyStroke04's Avatar
Ok after hours of searching for answers I give up hopefully I can get some help here as I usually do. I recently bought a mini maxx the box says 109003 made in early 2012 does this model need the high sulfer unlock to be able to do a dpf delete on my 2011 or does it already have it on it?
DaddyStroke04 is offline
post #2 of 9 Old 02-07-2014, 02:59 AM
You have to buy the unlock code so the tuner will work. Call H&S
2011 F250 6.7 3.55 gears
20" wheels,
Tonneau cover,
Chrome mirror covers and door handles,
Line-X bed liner,
LED grille lights amber,
EZ-down tailgate,
Tinted windows,
3.5"Ready lift kit
Amp steps
Bigtwinharley is offline
post #3 of 9 Old 02-07-2014, 04:31 AM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
or just buy an MCC unlock and then use an MCC tune such as SPE or Powerlabs and you will be all good !!
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #4 of 9 Old 02-07-2014, 04:42 AM
travisH3's Avatar
Feedback Score: 13 reviews
You need the 6.7 unlock code on h&s website I believe.
T-rav
2010 F350 6.4- H&S Single turbo kit, 5" flo pro,No limit SS cold side kit, No Limit intake, MPD billet CCV/oil filler, newton leveling kit, RED Newton traction bars, custom projector retrofit in oem lights and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 9 Old 02-07-2014, 06:27 AM
The easiest way to check your Mini-Maxx to see if it has DPF delete tunes is to plug it into your OSBII port, select your vehicle, then start the tuning process. IF your tuner is capable of deleting, there will be an option for PRESENT (DPF on) and one for REMOVED (DPF off).
Truckmaniac is offline
post #6 of 9 Old 02-07-2014, 08:07 AM Thread Starter
Ok yeah I'm thinking all I'll need is the 2011-2012 unlock and I'll be good that one is supposed to be delete capable out of the box without having to get the high sulfur unlock that require applying to the epa
post #7 of 9 Old 02-07-2014, 08:30 AM
Plug it in and check for the PRESENT / REMOVED option. Then you won't be having to guess if you need an unlock code or not. The part number you listed for your Mini-Maxx is a Race Tuner, so it should have delete tunes.
Where things got really confusing was when Ford changed the programming on the 2013-2014 trucks. On these years you have to use the new Street Tuner plus a High sulfur unlock OR reprogram with an MCC OR buy a unit that's been Hacked.
Like I said, plug it in and try it. You can load tunes in & out without risking your truck throwing codes or going into Limp Mode, as long as you DON'T START your truck. If the tuner has "Removed" tunes and it will load to your truck, you're good to go.
post #8 of 9 Old 02-07-2014, 09:41 AM Thread Starter
Thanks a lot I'll just have to plug it in when it gets here in the next day or so. But yes this has all gotten so complicated makes me miss my ole 6.0!!!
One more question when I get exhaust do I need with bungs or with out bungs or will either work ?
post #9 of 9 Old 02-07-2014, 12:02 PM
From this statement, I guess your Mini-Maxx is actually "in transit", so you can't try it out yet.
You need a delete pipe without bungs. You can unplug the sensor wires from the DPF at the wiring harness running next to the frame or you can remove the sensors from the DPF and zip-tie the sensors & wires to the frame.
