Doing DPF Delete & EGR Plates. Questions about DEF: To Drain or Not to Drain ??? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 15 Old 01-27-2014, 12:39 PM Thread Starter
I'll be deleting the DPF and installing EGR block-off plates on my 2013 sometime this week, thanks to my "Race Tune Friendly" Mini-Maxx Street Tuner. My mileage stinks and despite numerous trips to two dealers, they just can't seem to do anything about it. We're talking about mileage less than any of the stock 6.4's that I've owned. Anyway.....
For those of you who deleted your 6.7 trucks some time ago, What is the general consensus with the DEF (Diesel Exhaust Fluid) situation?
I'm planning on leaving the system "in place" in case I have to go back to stock quickly.
Should I drain the tank & lines?
or
Should I just leave the DEF in the tank?
There seems to be mixed "opinions" on the subject, so I'm looking to hear from experienced individuals who've been delete a while.
Also, I know that the Mini Maxx "turns-off" the DEF pump, but does it also "turn-off" the DEF heater?
Truckmaniac is offline
post #2 of 15 Old 01-27-2014, 01:51 PM
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
Interested as well...I could not find any solid info on this so I left mine the way it was...which was almost full
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #3 of 15 Old 01-27-2014, 01:55 PM
Same here it only had 900 miles on it
2014 350 ruby red cclb platinum, Mia parts with custom tunes
Gbhtrd06 is offline
post #4 of 15 Old 01-27-2014, 04:30 PM
Just deleted my 13 this last weekend. I left my def tank in place about 3/4 full. I did the flo pro delete pipe, h&s egr plates, mini maxx and an s&b and it runs great. Mileage on the lie o Meter is already climbing...if I can keep my foot outta it.
DrawDown is offline
post #5 of 15 Old 01-29-2014, 11:54 AM
I pulled my tank and got it cleaned out as good a possible, the DEF will go bad eventually and clog stuff up, at least what I have heard so I tried to get it cleaned out incase it ever goes back to stock
Matt
2011 F350 6.7L CC/LB SRW 4x4 King Ranch White Tri Coat
31 YNOT is offline
post #6 of 15 Old 01-29-2014, 07:12 PM
HighHP's Avatar
DEF has a shelf life of about 6 months, Itll go bad in the tank but the lines should be ok, the pump should have a purge feature where it sucks the fluid back from the lines into the tank when you shut it off.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #7 of 15 Old 01-31-2014, 04:23 AM
Anyone have a process on how to drain the tank? I'd like to drain mine but not sure how to do it other than syphoning.
Lrn5000 is offline
post #8 of 15 Old 01-31-2014, 05:35 AM
Cratos's Avatar
yea what he said!
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is online now
post #9 of 15 Old 02-09-2014, 10:56 AM
Left mine half full, have been deleted since brand new , now I have 46k deleted, no issues , other than turbo has a little shaft play, which I knew it wasn't going to last anyway, I have a after market coming will do the install this weekend, even with that said the truck stills runs like a champ
2012 f250 Ultimate Lariat, 6.7 powerstroke
Hunter69 is offline
post #10 of 15 Old 02-09-2014, 01:19 PM
Quoted: 4 Post(s)
So Hunter, can you give us the quick run down on after delete performance.
Fuel Economy?
Power? Same or Greater?
golfpineacres is offline
