SPE Full dif lock - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 26 Old 01-17-2014, 07:35 PM Thread Starter
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
SPE Full dif lock
I got the SPE full dif lock harness today...should be going on tomorrow. Will update on the install...got spent out with all the other stuff so now messing with a few inexpensive projects to hold me over till the next push.
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #2 of 26 Old 01-18-2014, 06:08 AM
99powerstroke62's Avatar
Quoted: 54 Post(s)
Been looking at doing this as well.
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #3 of 26 Old 01-18-2014, 01:59 PM
Quoted: 20 Post(s)
Can this be used on a non-tuned truck? Or do I need to have a tuner to remove an error code created by this? Or? Thanks in advance.
Sterling6.7 is offline
post #4 of 26 Old 01-19-2014, 08:19 AM Thread Starter
LORD OF WAR
This has nothing to do with being tuned...can be done on any truck with three locker.
87,96,04 F150 gone
"The War Wagon"
The Following User Says Thank You to nelson1each For This Useful Post:
Sterling6.7 (01-19-2014)
post #5 of 26 Old 01-19-2014, 08:26 AM Thread Starter
LORD OF WAR
Got the lock device installed. It's just a wiring harness that you have to splice in. On the passenger side floor up high on the right side is a control module. Directions have you un plug the black and brown plugs. Have to splice into one wire....cut 2 others than connect the harness to them. All necessary stuff is supplied. Just need wire cutter/stripper/crimper. A bit of a pain working under there but being lifted helped my back out so I wasn't so low. The instructions say your indicator light may or may not work. Mine does not....the only way I know I'm locked in now is if I try to take a turn with it on the tires will drag a bit.
87,96,04 F150 gone
"The War Wagon"
post #6 of 26 Old 01-19-2014, 10:49 AM
Dman115's Avatar
Just don't leave it locked when you shut your truck off. Will kill your battery.
Dman115 is offline
post #7 of 26 Old 01-19-2014, 11:07 AM Thread Starter
LORD OF WAR
Huh never thought about that...did this happen to you?
87,96,04 F150 gone
"The War Wagon"
post #8 of 26 Old 01-19-2014, 12:13 PM
Dman115's Avatar
Yup. I've heard from a few other guys too. Not a big deal just something to remember.
Dman115 is offline
post #9 of 26 Old 01-19-2014, 06:33 PM
Originally Posted by nelson1each View Post
Got the lock device installed. It's just a wiring harness that you have to splice in. On the passenger side floor up high on the right side is a control module. Directions have you un plug the black and brown plugs. Have to splice into one wire....cut 2 others than connect the harness to them. ...... The instructions say your indicator light may or may not work. Mine does not....the only way I know I'm locked in now is if I try to take a turn with it on the tires will drag a bit.
Sounds like a poorly "engineered" product. It should be "Plug & Play" and the indicator light should work for all applications, instead of being Hit-or-Miss.
I'll pass on this one!
Truckmaniac is offline
post #10 of 26 Old 01-20-2014, 02:02 AM
Dman115's Avatar
lol how are you supposed to have any fun if your just worried about a little light that won't be on the dash?! I mean my truck always says I need to service the advancetrac when I start it.... But I can also do doughnuts without my traction control stopping me!
Dman115 is offline
