Fuel Pump Whine after H&S Install? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 6 Old 01-14-2014, 07:11 PM Thread Starter
I finally did my DPF delete tonight on my 2013 F250 and when I finished, I went for my shakedown run. After doing my 3 transmission relearn passes I noticed a slight whine. I drove back to my house and it never really went away. I tried turning off the heat to see if it had to do with the AC and nothing changed. After getting back, I turned off and restarted the truck. The whine is definitely more noticeable in the garage idling. So then I turn the truck off and just turn the key to run and don't start it and the whine is very pronounced and coming from directly under the center of the hood? Sounds like a noisy fuel pump to me. Could this have to do with the delete? I have a 200 mile drive tomorrow and hope I don't get left stranded on the side of the road. Any ideas or help would be greatly appreciated.
Black F250 is offline
post #2 of 6 Old 01-15-2014, 10:57 AM
Cratos's Avatar
did you do the egr delete at the same time?
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
post #3 of 6 Old 01-15-2014, 03:40 PM
ucpa111's Avatar
Quoted: 2 Post(s)
Is your tank low on fuel? I've read about some whine when the tank level is low.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #4 of 6 Old 01-16-2014, 12:36 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
Subscribed.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 6 Old 01-16-2014, 10:38 AM Thread Starter
Sorry I haven't responded. The forum is acting up for me. The next morning I didn't have a whine at all and I have since driven almost 300 miles with no issue whatsoever. My fuel tank was completely full. I think it had something to do with the wastegate. It started when I did the full throttle pass to relearn the transmission. Regardless, it hasn't done it since.
post #6 of 6 Old 01-16-2014, 12:20 PM
Quoted: 3 Post(s)
Glad it turned out to be no problem at all.
Larry
14,000 LB GVWR,
Spray In Bed-Liner,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
