2012 f350 DEATH WOBBLE 12000miles - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 7 Old 10-22-2013, 06:50 PM Thread Starter
lcgoatboy's Avatar
Help! Death wobble at 60 mph. 6'' lift. 6.7 diesel. Stock steering stabilizer. original track bar. 35'' BFG all terrain. What to do, please & thanks.
lcgoatboy is offline
post #2 of 7 Old 10-22-2013, 06:55 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 181 Post(s)
Not enough caster. You can install dual steering stabilizers and it will most likely stop but most will tell you that is just band aiding the problem. You should also check the track bar bushing and joints for play.
Keith
2014 F250 Platinum FX4
AFE Intake
Sct x4
4" Dual Exhaust no muffler with 5" MBRP tips
4" BDS with Fox shocks
20x9 Gear Alloy Big blocks 0 offset
35" Toyo AT2's
Procomp Pro runner dual stabilizers
strokinpower is offline
post #3 of 7 Old 10-22-2013, 07:12 PM
KING of BLING!
ExtremeFord4x4's Avatar
strokinpower, is correct. Also check the torque of the upper track bar bolt. Whomever put the lift on may not have torqued it correctly. 405lbs is the proper torque spec.
2005 Ford Excursion 4x4 Limited(Current)
2006 F350 Crew Cab 6.0 Lifted 6",22's,SRL, Edge CTS(Totaled)
2003 F250 Crew Cab 6.0 Sonic Blue Sport 38s/20s(SOLD)
2001 F250 Crew Cab 7.3 w/ 08 Clip 37s/22x14s(SOLD)
2005 Excursion Limited 6.0 I.D. Tunes 38s/20s(SOLD)
2008 F350 Crew Cab 6.4 Job II 2.5" Leveling kit(SOLD)
2001 F250 Single Cab Short Bed Looney Tuned 6.0 Conversion Studded/EGR Delete(SOLD)
ExtremeFord4x4 is offline
post #4 of 7 Old 10-22-2013, 07:25 PM Thread Starter
lcgoatboy's Avatar
Thanks for the caster info. I've read the band aid solutions,this is why I decided to ask before I spend my new son in laws money. OR maybe he'll sell the truck to me cheap.lol
post #5 of 7 Old 10-22-2013, 07:27 PM Thread Starter
lcgoatboy's Avatar
I love this site,you guys will have this truck fixed by morning!
post #6 of 7 Old 10-23-2013, 07:42 AM
Skyd Ram's Avatar
Quoted: 36 Post(s)
I've also ran into a lot of DW issues on trucks running the larger BFG All Terrains like that. It seems that the sidewalls are a bit soft for these 8000lb trucks and can amplify any small issues in the front end.
Like others have said you will want to make sure that the truck has a minimum of 3 degrees of positive caster with 4-4.5 being even better. Then make sure that you don't have excessive play in the track bar bushings, track bar bracket and TRE's. Although HD or dual stabilizers will sometimes make the DW go away you will still have an underlying problem that will only get worse. Technically you should be able to drive these trucks without a stabilizer and not get DW. The main purpose of the stabilizer is to absorb the steering shock when you hit big bumps on one side or the other. This is both the transmit less feedback to the steering wheel as well as take a lot of shock stress off of components like the steering box, etc............
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
post #7 of 7 Old 10-23-2013, 08:00 AM
Quoted: 181 Post(s)
Let me ask this while we are all here discussing it. I had a problem with death wobble on my truck. I had all new tie rods a whole new track bar (even tried an $800 rip off guaranteed to fix your problem adjustable track bar that made the truck drive like crap) now back to a factory track bar, new drag link, all new ball joints new steering gear, different tires and a good alignment with 4 or more degrees positive caster and if I took my dual stabilizers off would have death wobble, what else is there to do?
Keith
AFE Intake
Sct x4
35" Toyo AT2's
