Life of '12 stock turbo - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 14 Old 10-04-2013, 12:22 PM Thread Starter
I been waiting on a warranty to run out before deleting. I have the race tuner in a box awaiting the much anticipated day of installation.
However, as quickly as I been hearing turbos fail after deleting, I am wondering if me leaving the DPF on for 36,000 miles may shorten the life of the turbo and blow up a lot sooner if I would have deleted it from the get go. Anyone have experience with waiting for the warranty and how long the turbos last after delete. I don't plan on hot rodding the truck but do want the power and to get the stupid emissions off.
Good part though is it seems like there are some good turbo kits coming out from good companies other than y'all know who. So if the turbo dies, I can replace it with a much better turbo.
Feel free to chime in on y'all's experience. Thanks in advance!
james_de62 is offline
post #2 of 14 Old 10-04-2013, 12:30 PM
Black2011SD's Avatar
In the same boat....kinda hoping for a catastrophe so I can get the turbo replaced, and then delete.
Black2011SD is offline
post #3 of 14 Old 10-04-2013, 12:33 PM Thread Starter
Same here. Having a brand new turbo right off the bat would be nice and good info to share if it does die on how long it lasted while deleted.
post #4 of 14 Old 10-04-2013, 12:49 PM
Elliott6.4's Avatar
Turbos dying were a common theme in early tune due to commanding higher boost than stock, this in turn, over speeded the turbos causing them to grenade. I think all the tuning companies have commanded less boost in attempt to keep the turbo closer to it's happy place. Keep in mind, there have been stock trucks that have had turbo problems, it has a super long shaft due to the dual compressor wheel which puts a lot of stress on the bearings. That's why kits with a single compressor wheel are becoming more popular.
Sent from AutoGuide.com App
2008 F-350 CC/SB 4X4
Job 1
Phalanx tuner with Spartan + KEM tunes to 275hp
AFE stage II intake
4" Flo-Pro DP-back Straight pipe exhaust
Elliott6.4 is offline
post #5 of 14 Old 10-04-2013, 12:53 PM
And they have the new hyper-balanced turbo they are replacing the failures with.
post #6 of 14 Old 10-04-2013, 08:54 PM
Randy_270's Avatar
Quoted: 2 Post(s)
Any one know the difference between Ford's version of the Garrett 3271 and an actual Garrett 3271? I know everyone says these turbos are crap but what if one were to buy a replacement from a Garrett dealer? Would it bolt in or has Ford changed enough of the turbo that it has to be a "Ford" version to fit?
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #7 of 14 Old 10-13-2013, 03:18 PM
Bump would like to know as well
torque beast is offline
post #8 of 14 Old 11-02-2013, 06:55 PM
Bump
post #9 of 14 Old 11-03-2013, 04:15 PM
matty21's Avatar
The 2015 powerstroke is coming with a new turbo. Should be able to get that turbo this time next year, not sure when your warrantee is up.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
http://www.facebook.com/video/video....91500544216050
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #10 of 14 Old 11-03-2013, 05:46 PM
Nailed it!
blacknight is offline
