COnfederate Diesel Turbo kit Actual pictures - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Closed Thread
post #1 of 116 Old 09-20-2013, 09:26 AM Thread Starter
I will post up actual pictures of a kit we pulled off of the line.
ID:	170833   Click image for larger version
ID:	170841   Click image for larger version
ID:	170849   Click image for larger version
ID:	170857   Click image for larger version
cfd_shop is offline
post #2 of 116 Old 09-20-2013, 09:27 AM Thread Starter
here are some more
ID:	170873   Click image for larger version
ID:	170881   Click image for larger version
ID:	170889   Click image for larger version
ID:	170897   Click image for larger version
cfd_shop is offline
post #3 of 116 Old 09-20-2013, 09:29 AM Thread Starter
and here are a few more
ID:	170913   Click image for larger version
ID:	170921   Click image for larger version
ID:	170929   Click image for larger version
cfd_shop is offline
post #4 of 116 Old 09-20-2013, 09:50 AM
Feedback Score: 3 reviews
You mean one you took down the street to the real welding shop just for a photo op? And those welds leave some to be desired
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #5 of 116 Old 09-20-2013, 09:52 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Honestly better than the ones going around but still not all that great, my buddy just started TIG welding and he showed me some of his welds and hell his are way better than that.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 116 Old 09-20-2013, 09:55 AM
RnEmOvr's Avatar
14 pictures posted but they only show 3 things. Mainly your ability to send parts out to be worked on by someone else.
Confederate Diesel, where only the finest JB Weld is used on your truck.
RnEmOvr is offline
post #7 of 116 Old 09-20-2013, 09:56 AM
MyTractorsSexy's Avatar
Quoted: 3 Post(s)
my thoughts exactly.
07 F250 Lariat ECSB bed FX4 6.0
leveling kit, DDM HID's
XD Strike 17x9 -24 offset 295/70/17 Hankook ATm
fox shocks & fox dual steering stabilizer kit
4in. straight pipe, Riff Raff boots, Beans sump
ARP's, Tuned, Deleted
coolant filter, bluespring, CAI
6.4 Banjo Bolts, BPD FICM
Alpine Head unit, 4 Hertz 140W door speakers, 2 rockford fosgate 10's, kenwood amps.
More pics in profile.
MyTractorsSexy is offline
post #8 of 116 Old 09-20-2013, 10:02 AM Thread Starter
Actual this is a typical example of the kit done by our welding professionals.
This is what a customer buying a kit should expect to see and if they do not see this minimum quality they can return the kit for a refund.
I will post more pictures of the headers and up pipes another day.
cfd_shop is offline
post #9 of 116 Old 09-20-2013, 10:15 AM
Then you owe Dan his money back - that kit was STEAMING, if you know what I mean - as in a pile of.....................
You just admitted dan his money back in an open forum - now I would sue you if I were him, again with the intent to tank your business, just how I roll.
And I took a screen shot for dan if he wants it so the edit button does you no good.
True Blue Metallic
post #10 of 116 Old 09-20-2013, 10:16 AM
RnEmOvr's Avatar
Then what happened to Dan? Did he get his refund yet?
RnEmOvr is offline
Closed Thread
