Rancho 9000 install question - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 6 Old 09-06-2013, 02:22 PM Thread Starter
Installed a set of 4 Rancho 9000xl's on my 12 F250. The stock shocks were a year old with 9000 miles, very little towing. I have had the new shocks on a week and haven't been impressed, the ride seems stiffer don't know about better. I now have what seems like a vibration or slight thumping feeling in the drivers side floorboard. It could be in my mind since I am focusing on everything thing, since I have installed these shock. My question is- I have checked all of the shocks and everything seems to be tight what could be causing this feeling?
On a side note, I thought I would change the shocks back to the factory ranchos just to see if the feeling was still there. I compressed the front shock and they had absolutely ZERO rebound, and the rears were terribly slow. I don't know if that is the way there are valved or they are just worn out. If anyone has any insight let me know.
Thanks
2012 f250 Ccsb Ultimate Lariat, Powerstroke FX4- Tuxedo Black, Bakflip F1
Lrdchaos is offline
post #2 of 6 Old 09-06-2013, 04:24 PM
broncojason's Avatar
There's another post here from someone saying their new 9000s seized up and rode really rough... May be worth pulling and checking.
Just food for thought.
2012 F250, Tuxedo Black, CCSB, 3.31, Banks Automind, leveled, Nitto Trail Grapplers.
broncojason is offline
post #3 of 6 Old 09-07-2013, 02:22 PM
peteoreo's Avatar
what setting are you running them on. I run mine on 5 and ride is supper.
Trucks,Guns,Harleys
2013 FX4 Lariat Supercab 8ft box/Westin-HDX grill guard/H&S minimax/DPF/cat/delete/afe4 inch exh/Rancho 4 inch lift/1250x35x20s
peteoreo is offline
post #4 of 6 Old 09-09-2013, 11:47 AM Thread Starter
I have tried different setting. Just put them on 2\2 and like the ride. Still have a certain feeling in the floorboard, like a slight banging. I have checked and everything is tight.
Lrdchaos is offline
post #5 of 6 Old 09-09-2013, 11:59 AM
"Stroker 8"'s Avatar
Quoted: 3 Post(s)
No issues here after my install, I have all 4 corners set at 3 and the ride is amazing. For towing, I will set the front to 5 and rear to 7 which still makes for a smooth ride. Not sure what your issue is. If I think of anything, I will post it up. Good luck, hope you figure it out.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 6 Old 09-16-2013, 06:45 PM Thread Starter
I believe I have figured out the issue. My drivers side Front shock will not compress. It seems to be locked up.
Lrdchaos is offline
