Tire Size - Speedometer Calibration? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 7 Old 08-26-2013, 12:43 PM Thread Starter
What devices out there will recalibrate the speedo of my 2012 F250 after adding a 35" tire?
I am not opposed to a tuner/programmer as well, but the speedo function is #1.
I see the Hypertech unit, but it only advertises correcting up to a 33" tire. The stock tire is more like 34".
TXST8tj is offline
post #2 of 7 Old 08-26-2013, 01:26 PM Thread Starter
Ok, leaning more toward NO tuning function. I'm really just not sure I want to risk effing up this truck for more power I can't say that I need.
Thinking about looking deeper into the Hypertech Speedo Calibrator.
Speedometer Calibrator - Hypertech
TXST8tj is offline
post #3 of 7 Old 08-26-2013, 06:46 PM
there is nothing out that works fords are to complex speed sensors go through the body control module. that includes the abs,traction control, navigation and hill decent.
cammel is offline
post #4 of 7 Old 08-26-2013, 06:55 PM Thread Starter
So the two Hypertech options don't work?
TXST8tj is offline
post #5 of 7 Old 08-26-2013, 08:20 PM
Randy_270's Avatar
Quoted: 2 Post(s)
I went from 275/70r18s(33.2" tall) to 325/65r18s (34.6" tall) and my speedo is only out by about half a mph without adjustment. There is a guy on here, cant remember his name, has 38" tires and a hypertech in-line module and he says his speedo is correct
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #6 of 7 Old 08-27-2013, 05:22 AM
The Hypertech does work. I have one and it works fine. The install and programming is pretty easy to do too. I would recommend it to you.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
post #7 of 7 Old 08-27-2013, 06:26 AM
Ok I just got off the phone with hypertech was told buy tech support that it will not work on a 2013 sd but its in the works. 2013 is different than the 2012
cammel is offline
