Just deleted and tuned. Truck won't run. Help please. - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 5 Old 08-25-2013, 11:19 AM Thread Starter
Just installed 5" dp back exhaust, egr blocker plates, intake and a mini maxx today. I ordered through SPE and got the hot-x tune. I installed the tune first, started truck and turned it off before doing anything else. Got everything knocked out and started the truck. It ran for 2 secs and shut off. They sent the MM #109007 which I was told would be all I needed.
I installed the MM and reinstalled it with the same results. I specifically asked when I bought it if I would need H&S to unlock the tuner and was told I wouldn't.
I checked the h&s site for the emission's unlock code but it says its not applicable with my part #. Better yet, even if I did need it I can only get one during business hours.
Is there something I'm not doing right? I need my truck to get to work in the morning. Any help would be appreciated. Thanks
zmgsvt is offline
post #2 of 5 Old 08-25-2013, 01:25 PM
Senderofan's Avatar
What year is your truck? You do need an unlock code from H&S....then you'll have the code from SPE for their hot tune...to unlock it and download to your rig. You need to contact your vendor and/or H&S. I think your ECM recognized that you deleted and will not run until you get the tuner on-line. Unfortunately....I don't think you'll be driving it in the morning unless you put all the emissions stuff back on.....unless you get the tuner unlock code and get that on line first. The SPE tune will come After the H&S is online with your ECM.
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #3 of 5 Old 08-25-2013, 03:08 PM Thread Starter
Thanks for the reply. The tunes I originally received didn't work. I sent SPE a message on Facebook and got a call soon after. Dan diagnosed and resent the tunes which fixed the problem. I have a lot of respect for someone that'll take time out of their Sunday to help a customer!
zmgsvt is offline
post #4 of 5 Old 08-25-2013, 06:27 PM
Quoted: 4 Post(s)
Glad it worked out today. Good customer service is hard to find.
Sent from AutoGuide.com App
Deerhunter4 is offline
post #5 of 5 Old 08-27-2013, 06:02 AM
That's soooo important. Local guy here, that I just used to put my '11 back to stock doesn't return email when you get dtc codes. Count me a lost future customer
bgrant_12002 is offline
