Turbo Back Exhaust install time. - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 12 Old 08-15-2013, 02:55 PM Thread Starter
RTRBURN's Avatar
All my stuff has arrived for my delete, I was wanting to know what is the typical install time on doing a 5" from the down pipe back? Also estimated time on a EGR delete? I work nights on a 12hr shift and only get 1 scheduled day off a month. Want to tackle it a day before work. Any help would be appreciated.
2011 Silver F250 Lariat CCSB 4x4 6.7 H&S Deleted (mine)
2012 Burgundy F350 Lariat CCSB FX4 6.7 (wifes)
RTRBURN is offline
post #2 of 12 Old 08-15-2013, 06:15 PM
Randy_270's Avatar
Quoted: 2 Post(s)
Depends on how good of a mechanic you are. Took me and a co-worker about 6 hours to do the dpf delete on my truck and took me about 45 minutes to do egr block off plates. Took me and the same coworker about 6 hours as well to do the turbo back exhaust on his 6.4. My friend is a fairly good sled mechanic but that's about all he works on and I can do basic maintenance on my vehicles and that's about the best of my ability haha.
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #3 of 12 Old 08-16-2013, 10:34 AM Thread Starter
RTRBURN's Avatar
No issue with mechanical skills, just didnt to run into a snag on a weekend and have to wait for Monday for support.
RTRBURN is offline
post #4 of 12 Old 08-16-2013, 01:49 PM
Axis2011KR's Avatar
The downpipe back isn't bad at all until you have to remove the last bolts supporting the DPF because that sucker is freaking heavy and almost impossible to do with one person unless you have a crawler or something that you can set it on and wheel it out from under the truck.
Things to have:
PB Blaster for the nuts/bolts that won't come off easily
Lots of socket extensions/flexi adapters mainly for the bolts on the downpipe/midpipe connection
6 pack of beer (optional but mandatory in my book)
I did it by myself in 2 hours and then a friend showed up just in time to help me pull the dpf out from under the truck and into the garage.
2015 F-250 King Ranch 6.7L CC FX-4
SCT+No Limit+FloPro
2011 F-250 King Ranch 6.7L CC 4x4 sold
H&S+S&B+Open Downpipe
Axis2011KR is offline
post #5 of 12 Old 08-16-2013, 02:28 PM
matty21's Avatar
Ya should be able to do it in 2 maybe 3 hours. Spray penetrating oil onto the bolts holding the exhaust together an hour before you start to let it soak. and spray the rubber hangers with a good silicon spray. Use a small jack under the DPF and a ratchet strap to make sure it doesn't roll off. Unplug the electrical sensors? then unbolt . a ratchet strap or cum-along is helpful for separating the pieces . Work from the DP towards the rear.
As for the egr. It's simple, 30-45 minutes to remove and block it off. I did all of this by myself. So if you have help it may speed it up, or slow you down depending on the helper lol
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
http://www.facebook.com/video/video....91500544216050
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #6 of 12 Old 08-16-2013, 05:29 PM Thread Starter
RTRBURN's Avatar
Ok thanks guys. I really appreciate the input. Do you guys recommend loading the H&S file first to make sure the PCM takes the flash? I have read where some have had problems trying to do first flash and had to take truck to dealer.
Another question is I hooked up the Mini Maxx yesterday, just ran the power and mounted everything, I didnt flash the tune yet...but my question is on the power wire... I used the white wire with the blue tracer and it is 12v Ignition hot like the manual says,, but it interrupts power during crank. It says in manual to make sure it has power during crank...anyone else have to use a different a different wire? I used a volt meter to test different wires but all where 5v or 10v or none. Thanks in advance.
RTRBURN is offline
post #7 of 12 Old 08-17-2013, 07:01 AM
2013F250Tank's Avatar
removed the DPF just myslef in the driveway with a floor jack in 2.5 hours. your just interupting power to the gauges the tune will always be on your truck. its also getting low voltage from OBD port thats why you can change the switch on the power box to ign or all the time on. I havent had issues with the interuption on my 13.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #8 of 12 Old 08-17-2013, 07:41 AM
matty21's Avatar
Yes do the download FIRST , while everything stock is still installed to make sure it takes. Once the tuning is good to go. Start on the exhaust.
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #9 of 12 Old 08-17-2013, 01:20 PM
Anth's Avatar
I'm not trying to derail the thread, but when I deleted my 12 I had to cut the exhaust down to size. It was a 5 in mbrp and it was to long, and the piece that went over the axle was to long to and it stuck way out past the side of the truck. So a buddy and I had to use a chop saw and cut it down to size. Thank goodness I was at his shop, if I was at home I wouldn't have had a chop saw. Is this normal?
2013 Platinum White, Dura Flaps, B&W turnover,
mpd s365 turbo kit, tuned by craig at mpd, no limit egr delete, amp steps, icon leveling kit, ouo traction bars, 20x10 bmf wheels, 35 toyo mt, bushwacker fender flares, painted to match headlights with projectors, absolute performance ccv kit.
Anth is offline
post #10 of 12 Old 08-17-2013, 08:33 PM Thread Starter
RTRBURN's Avatar
Sounds like you had a LWB kit...mines a Flo-Pro and has a LWB adapter.
Thanks again guys...got derailed this morning, oldest totalled his car this morning. Hope to knock it out tomorrow
RTRBURN is offline
