AIRDOG 165 - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 8 Old 08-12-2013, 06:56 AM Thread Starter
AIRDOG 165
HAS ANYBODY INSTALLED AN AIRDOG 165 ON A 2012-13 JUST WONDERING HOW LONG IT TOOK AND ANY NOTICABLE IMPROVEMENT, HAVE IT SITTING IN THE FLOOR READY TO PUT ON.
VACARELLAB is offline
post #2 of 8 Old 08-13-2013, 05:30 AM
hw713713's Avatar
I have. Pretty easy install with the quick connects. Only issue I had was using the recommended fuse tab it threw all kinds of fault codes. Tried to find a wire that got hot on remote start and could not find one. So I wired it to AUX switch. Lost remote start feature however the truck will start just the AD not run and I can't imagine that is healthy on the factory FP. Other than that pretty easy. Much easier than all the dodges I have installed on.
Sent from AutoGuide.com App
2012 F250 KR, H&S mini max, full delete, Carli 2.5" pin top w/full replacement leafs, S&B intake, ADII and a camper shell!!!!
2013 Touareg TDi (mommas ride) She won't let me touch it.
hw713713 is offline
post #3 of 8 Old 08-13-2013, 08:22 AM
Why don't you tap the same fuse that the Minimax does?
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #4 of 8 Old 08-13-2013, 10:10 AM
hw713713's Avatar
Tried. Draws to much juice or something. Throws all kinds of fault codes
hw713713 is offline
post #5 of 8 Old 08-13-2013, 10:16 AM
I'm surprised it's not operating thru a relay already, but for sure a high amp draw like that motor should not pull directly off the fuse block.
post #6 of 8 Old 08-13-2013, 10:34 AM
RTRBURN's Avatar
I would install a rated amp relay and trigger it by an Ignition Hot source.
The AD is one of my next Purchases
2011 Silver F250 Lariat CCSB 4x4 6.7 H&S Deleted (mine)
2012 Burgundy F350 Lariat CCSB FX4 6.7 (wifes)
RTRBURN is offline
post #7 of 8 Old 08-14-2013, 04:52 AM
hw713713's Avatar
Looking at one of these and the AD.
http://www.dieselsite.com/fuelsystems-cpr.aspx
Would this be overkill? I can not find anything how good the AD is at getting the water out. Thoughts?
hw713713 is offline
post #8 of 8 Old 08-16-2013, 08:13 PM
Bryce18's Avatar
Quoted: 17 Post(s)
This may be a dumb question but can't you tap into same power source as the factory fuel/water seperator?
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
