Emissions testing help - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 7 Old 07-19-2013, 06:20 PM Thread Starter
Hey guys, I'm new to powerstrokes/diesels in general, I have a 2011 f250 and I was wondering if I tune it can i pass emissions, I'm out of the Chattanooga TN area, and I was planing on spartan tune, afe dpf delete pipe, and then a cold air intake and a h&s egr delete. My question is, is there any possible way to pass, my concern would be the visual test and the dpf delete, please help me!
thatguyjeffrey is offline
post #2 of 7 Old 07-20-2013, 12:35 AM
BIG Laing's Avatar
A lot of guys on here return to stock for testing. Sorry, IDK if you could pass while deleted.
Take this as a free
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 7 Old 07-20-2013, 09:12 AM
BigGreen06's Avatar
Quoted: 71 Post(s)
I've passed while deleted in NY, but that's mainly do to it being my friend that does the testing.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen; www.oslights.com
BigGreen06 is offline
post #4 of 7 Old 07-20-2013, 10:41 AM
I don't live in an emissions place, but it's common sense that you would never pass a visual inspection alone....
2012 F350 Lariat SRW CCSB 4x4 - Vermillion Red
Icon 7" Lift, BMF Novakane, 37x13.5x22 Toyo MT, MBRP Filter Back, 2WD Chin Spoiler, RDS 150 Gallon Tank
turboryan is offline
post #5 of 7 Old 07-20-2013, 11:15 AM
I_AM_RP3's Avatar
I would think that if the truck passed without it, ford wouldn't have put it on there. But in a state that does test for emissions, you won't pass. Unless you know someone or get lucky
I_AM_RP3 is offline
post #6 of 7 Old 07-20-2013, 01:55 PM
Ya know, I cam from a long line of dodge trucks before this. In my '08, I had a smarty tuner, there was a setting that only provided 50% of the fuel of stock programming. Smarty guranteed that it would pass emissions testing as long as they visual was passed. Which just required a stealthy stock looking delete pipe. I wonder if some of our mcc vendors could make some type of emission tuning, that would really de-rate the motor for emission reasons.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #7 of 7 Old 07-23-2013, 12:14 PM
Blackie13's Avatar
Most states utilize the OBDII port to verify the engine is performing as intended and not making a code. Most tuners will otherwise be using the OBDII port. Unplugging it may cause a check engine lite which would cause you to fail. If your state is using a sniffer shoved up the tailpipe you most certainly would fail without your emissions equipment on. There are some states that allow private garages to perform the testing and possibly knowing somebody or a healthy bribe will get you the passing grade.
Blackie13 is offline
