Truck threw a code yesterday, died running down the road! - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 4 Old 07-13-2013, 06:31 PM Thread Starter
P0093 - Fuel System Leak Detected - Major Leak
Yesterday, was headed on my normal 650 mile commute to work, came up on an SUV driving slowly behind a semi truck. Went to pass, hammered down full throttle, truck down shifted to 4th, and when the truck made the 4-5 shift under full throttle, truck limped, check engine light came on, loss of all power, was bout 3/4 way around the semi, put the truck into neutral coasting, and the engine shuts down! Got pulled over, cleared the code, truck started right back up, no issues since the incident. Anyone have any problems like this? A major fuel leak, would that be in the line between the tank and the injection pump, or loss of pressure in the CP4/fuel rails detected? Hard to say, alls I know it freaked me out, and had I not been on a desolate stretch of montana highway with NO traffic, this could have gotten me hurt in Denver where I live.
Truck only has 3300 miles thus far, so the lift pump or Cp4 should still be in good shape. I searched and only one other thread came up where a guy had the code, was running the 160 spartan tune when it occured.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #2 of 4 Old 07-14-2013, 05:24 AM
Hawkeye Diesel's Avatar
Check your fuel cap, if its not on properly it can cause a system fault
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #3 of 4 Old 07-14-2013, 05:56 AM
BlackSheep5's Avatar
The truck is not going to die from the tank cap being loose or off.
Sent from AutoGuide.com App
From PTS
P0093 Fuel System Leak Detected - Large Leak
Description The powertrain control module (PCM) monitors the fuel volume control valve value necessary to maintain a desired fuel rail pressure and sets a DTC when the set point needed for the fuel volume control valve to maintain desired fuel rail pressure exceeds a calibrated limit.
Possible Causes Fuel system leak
Diagnostic Aids This DTC is set when the PCM detects the requested fuel volume control value exceeds a calibrated threshold indicating a large fuel system leak.
The PCM may disable the low pressure fuel pump causing a no start condition when this DTC sets.
BlackSheep5 is offline
post #4 of 4 Old 07-14-2013, 06:18 AM
The plug for that sensor is in the engine galley behind and down from the throttle body. Start there
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
