Minimax and EGTS - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 5 Old 06-30-2013, 12:31 PM Thread Starter
Blackie13's Avatar
Minimax and EGTS
Imk sure this has been answered numerouse times but I could not find anything in the search. Installed a minimax and deleted the dpf the tune downloaded fine and truck runs fine. My question is that the EGTs that are recording on the mini max do not make sense. Shows Im running 2500 somtimes more I hit the gas they drop to 1800. I have not did the erg delete yet hopefully next weekend so Im guessing the connector to the factory piro is not picking up anything because its not hooked in or is there another reason I'm all over the place
Blackie13 is offline
post #2 of 5 Old 06-30-2013, 12:47 PM
BIG Laing's Avatar
You are right, it has been answered many times. I can't seem to find a thread on the subject either. I know it has something to do with the pyrometer source. You either have it selected on "stock" or "H&S" and just need to select the other one.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 5 Old 06-30-2013, 04:50 PM
having the same problem am i goin to damage my truck if i drive it like this
08 F350 Fx4 cc sb 4" downpipe back exhuast dpf deleted afe intake w/ H&S minimax tuner R.I.P.
2013 F350 Platinum edition
nystrokin516 is offline
post #4 of 5 Old 06-30-2013, 05:45 PM
Guys...........install one of the factory pyro probes that you pulled out of the stock exhaust, install it into the egr blocker plate that is tapped for a agt probe, then plug the probe into the wiring harness right by the front of the EGR cooler. Then switch your EGT source on the minimaxx to factory and you should have correct egts coming through on the monitor.........
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #5 of 5 Old 09-02-2013, 01:04 PM
2013F250Tank's Avatar
correct H&S uses the EGR probe, Powerlabs uses the EGR prob, SPE uses the DPF probe.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
